Adjusting thickness of the subtitle outline
Limpi1978
Post by Limpi1978 »
Hey,
is there a way to adjust the thickness of the subtitle outline? I find it a bit too thick.
I found no corresponding setting in the GUI, but maybe it is possible by editing a settings XML file (without jailbreaking my Apple TV 4K)?
Also I would like to add more subtitle fonts (TTF files) if possible.
Limpi1978
Re: Adjusting thickness of the subtitle outline
Post by Limpi1978 »
I found this workaround (using ASS/SSA subtitles):
https://forum.kodi.tv/showthread.php?tid=213446
That works, but also is a pain in the ass :) to always convert .srt files to .ass files...
I just would like to set the outline thickness. Everything else is fine for me.
