TV Stuttering
Wouter
TV Stuttering
Post by Wouter »
Hello support,
I want to report an issue i see for a long time with using Mrmc. It holds me back to use it on a daily basis. You can see it when a live ticker is visible or with sports on screen. The motion is not fluent.
Disabling hardware decoding makes it a lot better but still not completely fluent.
When using Kodi 19 on the AppleTV it is completely fluent and no stuttering visible
This issue is in Mrmc from the beginning, could this be fixed please?
eazytv
Re: TV Stuttering
Post by eazytv »
You sure your stuttering is not emanating from whatsoever settings, i.e. Hz etc? I do not have any stuttering at all, smooth as butter. As it always been.
If you want anyone to help, you need to provide information on your setup, settings of devices involved and a debug.log. However, you will realize the owners of the app have not replied anywhere on the forum for a very long time. So you better not expect any help.
Wouter
Re: TV Stuttering
Post by Wouter »
Please compare to Kodi 19 on AppleTV, now that is silky smooth.
Settings are default, 50hz TV and no hardware decoding
You can see it has problems with live tickers running on screen. It stutters ones in a while and is not smooth.
