Skip Intro button / function
C_i_X_e_l
Now that Plex is scanning and writing the intro skip timing into the xml, is there a possibility to include the "Skip Intro" feature into the UI for those items that have it?
Re: Skip Intro button / function
It’s possible, need to check if we have access to the skip timing via API... plex API is not very well documented
C_i_X_e_l
Makes sense.
I did notice that the Composite plugin via Kodi seems to tap into this:
https://github.com/anxdpanic/plugin.vid ... e_for_plex
If it's helpful
If it's helpful
sylvio2000
Any news on this feature?
Working on it, I’ll keep you posted on a progress
- timstephens24
It's part of PlexKodiConnect (https://github.com/croneter/PlexKodiConnect), too.
Just looking for a best way to display the button, having 4 skins and “Siri expert” option makes the whole thing 8 times as complex
in core Plex -> https://forum.mrmc.tv/viewtopic.php?f=10&t=5653
- only shows once, auto hides after 5 seconds and it will not show again until video is restarted
- Ariana skin only for now, Opacity will be done once the core logic is finished
