Hello
MRMC was working perfectly during 2 Years
Yesterday, I have tryed to start MRMC, MSG 'Start Services' was diplayed during 20 Secondes and MRMC stop to work.
I had to reinstall MRMC to solve this Problem.
I have set SQL Service like before and the Problem has reappaired.
Any help to resolve this Problem will be welcomed
Thank you in advance
Regards
JP
MRMC doesn't start anymore
scoubidou
Re: MRMC doesn't start anymore
Hello
My problem has been resolved by replacing mrmc by KODY !!!!
Advantages :
- Kody is free
- Support of Kody is real ( no Answer for my mrmc Problem after 2 Weeks...)
Unfortunatly, I can't ask for mrmc refund
My recommandation for all : avoid to buy mrmc with no Support !!!!!
Advantages :
- Kody is free
Glad you found the right solution for it, sorry we couldn’t help without the debuglog.
scoubidou
No reason for the attitude, we are not sitting next to your setup to be able to troubleshoot it. At the minimum we need to see some logs to be able to help.
Logs can be pulled using adb or similar if the app doesn’t start...
Enjoy Kodi, see you next time!
