Serious bug with Black Glass Nova skin
whatgift
Post by whatgift »
If the "Ken Burns effect on backdrops" setting is enabled on the Black Glass Nova skin, the "select/ok" command stops working, which basically stops you from doing anything on the app. The only resolution I have had is to delete and reinstall the app. I have tested this several times, and happens every time.
I'm using an Apple TV 4 (1080p version) with latest tvOS installed (13.4.8).
Ufotofu
Re: Serious bug with Black Glass Nova skin
Post by Ufotofu »
I posted about this on 23 Dec 2018.
