The movie information in file view does not work when clicks touchpad. Only playback works.
Works properly with a media library.
Version 3.9.7
Movie info not work in file view
Re: Movie info not work in file view
can you give us a bit more information on this? screenshot and a debuglog are a good start... "doesnt work" is not enough unfortunately.
file view is just that, file view... if you would like it in a library, then just add it into library
Zlatan77
Settings: https://drive.google.com/file/d/1fqVE-B ... p=drivesdk
Click show information does not work anything:
https://drive.google.com/file/d/1Ds4vqr ... p=drivesdk
Before the 3.9.7 update works well.
I cant open any of the links.
Zlatan77
Sorry. I fixed the link.
ok, should be fixed in for next version/TestFlight. Thanks!
Zlatan77
Thank you. I'm waiting.
One more thing:
The TVShow name is bad in hungarian translation.
Correct: Sorozatok
This is also correct before the upgrade. (3.9.7)
One more thing:
Correct: Sorozatok
Zlatan77
Unfortunately the 3.9.9 not perfect.
Default select action-show information.
Nonetheless choice displayed.
