upgrade to 3.9x reset mysql watched status?
monkeh
Post by monkeh »
Hi
Im currently on 3.81 and have held off upgrading because I read that people lost their watched status on their mysql databases :( and with the number of TV series we watch this would be a major pain in the @ss.
So If I upgrade now to the latest version will it upgrade the DB and retain the watched status?
P
Re: upgrade to 3.9x reset mysql watched status?
I have had no issues with it, you can make a backup of your MySQL database just in case
monkeh
Post by monkeh »
Thanks, upgraded now, simple process and it works perfectly, I found a previous mymovies116 DB which I dropped prior to the update.
I could then upgrade all my librelec RPi2 systems which has seem them work much faster through the menu's :)
