Hello,
Running MrMC with Hue Client on my Nvidia Shield 2019. When activating continuous Hue transmission, everything works fine as long as I minimize or change windows with other apps. if, for some reason, MrMc exists/restarts/force closes, then the app won't start again. It crashes right after the "Starting services" message. I then need to delete data (cache alone doesn't help) and setup everything again.
This behaviour occurs only when using the continuous Hue Transmission option. I would really like to use the continuous transmission since it even works in the OS with other apps as long as MrMC is minimized. I can provide logs tomorrow if requested.
Any ideas?
Thanks in advance
MrMc crash on startup when hue client continuous is active
m33ts4k0z
Re: MrMc crash on startup when hue client continuous is active
We definitely need the debuglog, let’s wait for @koying to comment also
m33ts4k0z
Thanks for the reply. Here it is.
