Unable to play The Matrix Bluray rip
waldo22
Post by waldo22 »
I'm unable to play a Bluray rip of "The Matrix" on my 2017 Shield and I'm not sure why.
MrMC tries to play the file and the audio starts, but the video is always blank. After a short period, the audio cuts out as well.
I don't know if I got a counterfeit Bluray or not, but it looks legitimate.
The video plays perfectly fine with Windows "Movies & TV" and also with MPC-HC on Windows 10.
It's WVC1, and I ripped it to an MKV container without transcoding using MakeMKV.
Is this due to the content being WVC1?
Here are the properties from MPC-HC:
Video: WVC1 1920x1080 23.976fps [V: English [eng] (vc-1 advanced L3, yuv420p, 1920x1080)]
Audio: Dolby AC3 48000Hz 6ch 640kbps [A: Surround 5.1 [eng] (ac3, 48000 Hz, 5.1, 640 kb/s) [default]]
Audio: Dolby AC3 48000Hz 6ch 640kbps [A: Surround 5.1 [eng] (ac3, 48000 Hz, 5.1, 640 kb/s)]
Audio: Dolby AC3 48000Hz stereo 192kbps [A: Stereo [eng] (ac3, 48000 Hz, stereo, 192 kb/s)]
Audio: Dolby AC3 48000Hz 6ch 640kbps [A: Surround 5.1 [fra] (ac3, 48000 Hz, 5.1, 640 kb/s)]
Audio: Dolby AC3 48000Hz stereo 192kbps [A: Stereo [spa] (ac3, 48000 Hz, stereo, 192 kb/s)]
Subtitle [S: English [eng] (pgs)]
Subtitle [S: French [fra] (pgs)]
Subtitle [S: Spanish [spa] (pgs)]
Subtitle [S: Forced Subtitles (auto)]
Subtitle: UTF-8 [S: No subtitles]
If there's nothing obviously wrong, let me know and I'll post a debug log.
Thanks!
Fehritale
Re: Unable to play The Matrix Bluray rip
Post by Fehritale »
As I can see your video use VC-1 as codec. The shield seems to have Problems with decoding VC-1.
Have a look https://www.nvidia.com/en-us/geforce/fo ... en-screen/
waldo22
Post by waldo22 »
Wow, good find!
I'll check some more VC-1 content and post on the Nvidia forum.
-Wes
maddog510
Post by maddog510 »
waldo22 wrote: 07 Feb 2020, 21:52 Wow, good find!
-Wes
Try converting it to H.265
