Uploading CA cert how?
borussia
Post by borussia »
I recently switched all my local network devices to be accessed via HTTPS (based on self signed certificates). My problem is that I can't stream any https streams from my vu+ receiver (via PVR plugin). Is there any way to access the MrMC install path to put the CA cert there (for MrMC to trust the https connection to my PVR)?
I came across that link here, that's why asking...
https://forum.kodi.tv/showthread.php?ti ... pid2735088
Thanks,
Stefan
Jarvismeier
Re: Uploading CA cert how?
Post by Jarvismeier »
Have you installed the CA cert onto your AppleTV?
borussia
Post by borussia »
Yes, successfully via Apple Configurator (Profile)
