Mrmc hang after pressing play
Konstantin
Post by Konstantin »
mrmc hang when I choose title and press play button. There are black screen and nothing happens, after a few seconds I see a film frame for a second and black screen again.I suppose it starts after update to 3.9.3
I deleted and reinstall the app, but have the same problem.
Debug log Y7KYK.log
Re: Mrmc hang after pressing play
as a test, turn off adjust refresh rate in MrMC.
Konstantin
It helps, thank you!
Konstantin wrote: 02 Jan 2020, 08:35 It helps, thank you!
You might increase the delay after refresh rate change.
