Database Migration fails
DerMarco
Post by DerMarco »
The latest MrMC update on tvOS screws up my MySQL database. It is not usable anymore in other Kodi/LibreELEC instances. It creates a new database MyMovies116 for the current Kodi version, but this one is somehow corrupted. I cannot get the movies screen on my LibreELEC raspberry to display properly. Latest additions are missing and cannot be accessed at all. The Raspberry has LibreELEC 9.2 installed, which supports the current DB version.
When i drop the migrated database 116 and let the Rasberry do the migration from 107 to 116, all is back to normal and also MrMC can use this version.
Pretty simple workaround, just thought it might be helpful for some.
mrmrox
Re: Database Migration fails
Post by mrmrox »
Thanks, I already didn't undersand why my Kodi was not in sync with MRMC.
Apparently, MrMC 3.9.3 upgrade the MyMovies database (and I noticed the MyMusic doesn't get upgraded) without knowing while Kodi (I am using kodi-headless krypton docker).
Pulling the kodi-headless Leia and connecting to the mysql database provided an empty Movie database via Kodi headless Leia webpages.
I can confirm the procedure also worked for me:
- MrMC 3.9.3 upgraded the movies database to MyMovies116
- Stop any Kodi clients (my kodi headless docker)
- Drop the MyMovie116 database in mysql
- Start the kodi headless Leia Docker
- Both the MyMovies and MyMusic database version for Leia are created/upgraded by Kodi
- Updates via MrMC are now visible via the kodi headless web pages.
