I have added my music through a upnp source. Using the stock white skin. I don't know how to add music to the home screen. I see that I can add it as a favorite. But I would like it to be a tile like when you add TV shows or movies.
Is this possible?
Add music to main screen?
Re: Add music to main screen?
It’s possible through the library, you have to create music library by adding the the source and letting MrMC scan it in.
lightsout
I thought that's what I did. I went into media sources and then music, and then add music.amet wrote:It’s possible through the library, you have to create music library by adding the the source and letting MrMC scan it in.
I added a upnp source, it scanned and the music is there. But I have to go back into; media sources, then "music" to listen to it.
I would like to see a folder on the home screen.
UPNP can’t be added as library source, you will have to do what was done for videos, add smb/nfs and scan that in
lightsout
What's the difference. It's a network location and it scans in just like SMB does. I'll try it out. The reason I even tried upnp is because I couldn't get SMB to connect to my win 10 machine. It works on Kodi but get refusing the connection.amet wrote:UPNP can’t be added as library source, you will have to do what was done for videos, add smb/nfs and scan that in
For my Movies and tv I have logged into Emby.
You can try different smb options in MrMC based on how your win 10 is setup, smb2 might be an option.
I know that music library works well with Plex integration, if that helps in any way... I think emby one is also fine
EDIT: just tested emby music and I see no issues here, have you tried adding a music library to Emby?
lightsout
My music actually is included in Emby but I hate how it organizes it. I have it broken down into about 8 large folders for things like; flac, sacd, etc. Within mrmc these aren't respected and it's a jumbled mess.amet wrote:You can try different smb options in MrMC based on how your win 10 is setup, smb2 might be an option.
But I figured it out. Pulled out the keyboard because I was going to setup SMB again. And I tried long pressing on music section and there it was. "Add folder to home screen". So it worked with upnp.
I looked far and wide fire a way to remove some of the folders on the home screen from Emby. I use mrmc for specific usage. But Emby has a bunch of libraries I'd like to hide.
Didn't see the option. I could do it on Emby but they would then be hidden in other apps.
