Under subtitles on the top menu, it also says off.
Under system settings -. Preferred subtitle language, it's set to forced only (which is what I actually want), but also tried none.
If I play the video in infuse, no subtitles.
If I move the video so Emby can see it, it plays with no subtitles.
If I play it with vlc, no subtitles.
If I look at it with mediainfo or ffprobe, the pgs subs are not a default track and it is not forced.
I cannot find a way to not show the subtitles, any hint?
Tvos 13.0, mrmc paid 3.9.2
General
Unique ID : 294841482416225707998259623825136195658 (0xDDD0676B72F851C0D164BB6CB530984A)
Complete name : /Raid/NoArchive/MultiMediaTest/Movies/War/Saving Private Ryan (1998).mkv
Format : Matroska
File size : 33.8 GiB
Duration : 2 h 49 min
Overall bit rate mode : Variable
Overall bit rate : 28.6 Mb/s
Movie name : Saving Private Ryan
Encoded date : UTC 2019-10-09 07:13:01
Writing application : HandBrake 1.2.1 2019021900
Writing library : Lavf58.20.100
ErrorDetectionType : Per level 1
Video
Format : HEVC
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Writing library : x265 2.9:[Linux][GCC 7.3.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=24.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Bit rate mode : Variable
Channel(s) : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : 48.0 kHz
Bit depth : 24 bits
Title : Surround
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 2 h 41 min
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : :Chapter 1
00:04:30.228 : :Chapter 2
00:13:46.993 : :Chapter 3
00:18:56.844 : :Chapter 4
00:26:53.362 : :Chapter 5
00:36:11.753 : :Chapter 6
00:45:47.328 : :Chapter 7
00:57:39.414 : :Chapter 8
01:05:26.673 : :Chapter 9
01:13:45.755 : :Chapter 10
01:17:42.408 : :Chapter 11
01:24:05.082 : :Chapter 12
01:35:29.724 : :Chapter 13
01:46:43.522 : :Chapter 14
01:59:35.877 : :Chapter 15
02:07:25.930 : :Chapter 16
02:17:11.932 : :Chapter 17
02:26:54.306 : :Chapter 18
02:32:42.612 : :Chapter 19
02:42:38.916 : :Chapter 20
