4K file stutter
Alain13
4K file stutter
Post by Alain13 »
The following file stutters when played throug MrMc (source: Plex Media Server):
http://distribution.bbb3d.renderfarming ... normal.mp4
It doesn’t matter which combination of AVF/VTB acceleration I use.
Log: IVH91.LOG
When played through Plex Apple TV app, it runs smoothly.
Even on iPadOS played through MrMc it stutters and played through Plex app everything is fine. Even just clicking on the above link on the iPad plays it smoothly.
Hope something is visible in the debug log.
Thanks!
Alain13
Re: 4K file stutter
Post by Alain13 »
Sorry my bad, I remuxed the above mp4 file a while back to an HEVC 4K mkv file. So the mp4 file plays fine through MrMc, but the remuxed to H265/mkv one not (played in the debug log), while other players like Plex plays it fine.
Re: 4K file stutter
debuglog, that is turn on debug, not just post the normal log. :)
Alain13
Re: 4K file stutter
Post by Alain13 »
That is strange, because I exactly did those steps. Will try it again later on the day.
Alain13
Re: 4K file stutter
Post by Alain13 »
TOYW8.log
Re: 4K file stutter
22:13:14.083 T:6142849024 DEBUG: Open - av_find_stream_info finished
22:13:14.083 T:6142849024 INFO: ffmpeg[16E247000]: Input #0, matroska,webm, https://192.168.0.1:32400/library/parts ... 07/file.mk':
22:13:14.083 T:6142849024 INFO: ffmpeg[16E247000]: Metadata:
22:13:14.083 T:6142849024 INFO: ffmpeg[16E247000]: encoder : libebml v1.3.0 + libmatroska v1.4.1
22:13:14.083 T:6142849024 INFO: ffmpeg[16E247000]: creation_time : 2014-06-10T08:46:02.000000Z
22:13:14.083 T:6142849024 INFO: ffmpeg[16E247000]: Duration: 00:10:34.53, start: 0.000000, bitrate: 6126 kb/s
22:13:14.083 T:6142849024 INFO: ffmpeg[16E247000]: Stream #0:0(eng): Video: hevc (Main), yuv420p(tv), 3840x2160, SAR 1:1 DAR 16:9, 60 fps, 60 tbr, 1k tbn, 1k tbc (default)
22:13:14.083 T:6142849024 INFO: ffmpeg[16E247000]: Stream #0:1: Audio: aac (LC), 48000 Hz, 5.1, fltp (default)
22:13:14.083 T:6142849024 DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
22:13:14.083 T:6142849024 DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1
22:13:14.084 T:6142849024 DEBUG: CDVDInputStreamFile::SetReadRate - set cache throttle rate to 842366 bytes per second
22:13:14.084 T:6142849024 NOTICE: Opening stream: 0 source: 256
22:13:14.084 T:6142849024 NOTICE: Creating video codec with codec id: 174
22:13:14.084 T:6142849024 DEBUG: FactoryCodec - Video: vtb - Opening
22:13:14.084 T:6142849024 NOTICE: CBitstreamConverter::Open invalid hvcC atom data
22:13:14.084 T:6142849024 DEBUG: FactoryCodec - Video: vtb - Failed
22:13:14.084 T:6142849024 DEBUG: FactoryCodec - Video: avf- - Opening
22:13:14.084 T:6142849024 DEBUG: FactoryCodec - Video: avf- - Failed
22:13:14.084 T:6142849024 DEBUG: FactoryCodec - Video: - Opening
22:13:14.084 T:6142849024 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
22:13:14.084 T:6142849024 DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 4 threads
22:13:14.084 T:6142849024 DEBUG: FactoryCodec - Video: ff-hevc - Opened
something off with the HEVC 4K mkv file, I'd like a sample and/or mediainfo for it.
Alain13
Re: 4K file stutter
Post by Alain13 »
Link to video:
https://bit.ly/2o2jF8z
MediaInfo:
General
Unique ID                                : 86015745233769118449801053766252904485 (0x40B607AA5FBA4F5FC332E55F3CA24025)
Complete name                            : D:\OneDrive - PC Graphics\Public\bbb-4k-60hz.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 463 MiB
Duration                                 : 10 min 34 s
Overall bit rate                         : 6 126 kb/s
Encoded date                             : UTC 2014-06-10 08:46:02
Writing application                      : mkvmerge v6.8.0 ('Theme for Great Cities') 64bit built on Mar  5 2014 14:50:33
Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 60.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : A_AAC-2
Channel(s)                               : 6 channels
Channel layout                           : C L R Ls Rs LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Compression mode                         : Lossy
Default                                  : Yes
Forced                                   : No
Re: 4K file stutter
Your mkvmerge version is 5 years old :) Please try something newer.
Alain13
Re: 4K file stutter
Post by Alain13 »
Hmmm probably an old test or so I did, because normally I always use the latest Handbrake for conversion. I remuxed the original file with Handbrake and that plays perfectly indeed!
Thanks for the information!
