Often I resume my AppleTV from sleep and the TV Guide seems to still display shows from when the AppleTV went to sleep and it doesn't move to the shows that are currently on. Seems I need to go back to the menu and then into the guide again to fix it. I've pasted the log but don't see anything obviously relevant...
21:24:18.802 T:6102986752 NOTICE: CDVDPlayer::CloseFile()
21:24:18.802 T:6102986752 NOTICE: DVDPlayer: waiting for threads to exit
21:24:18.802 T:6102986752 NOTICE: DVDPlayer: finished waiting
21:24:20.257 T:6102986752 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'OverlayHD.png'
21:24:20.358 T:4426848256 ERROR: Previous line repeats 4 times.
21:24:20.358 T:4426848256 NOTICE: starting zeroconf publishing
21:24:20.358 T:4426848256 NOTICE: WebServer: Started the webserver
21:24:20.358 T:4426848256 NOTICE: starting upnp client
21:24:20.359 T:6114455552 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
21:24:20.359 T:6114455552 NOTICE: UDP: Listening on port 9777
21:24:20.383 T:6102986752 NOTICE: CDVDPlayer::Opening: pvr://recordings/active//Insiders/Insiders Fran Kelly joins Malcolm Farr, Dennis Atkins and Sarah Martin to discuss the week in politics including PM Morrison's official state visit to the US, climate policy, security in the Indo-Pacific region and drought relief., TV (ABC 1), 20190928_230130.pvr
21:24:20.383 T:6102986752 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:24:20.383 T:6121910272 NOTICE: Creating InputStream
21:24:20.385 T:6121910272 NOTICE: Creating Demuxer
21:24:20.525 T:6121910272 NOTICE: Opening stream: 0 source: 256
21:24:20.525 T:6121910272 NOTICE: Creating video codec with codec id: 28
21:24:20.525 T:6121910272 ERROR: CBitstreamConverter::Open avcC data too small or missing
21:24:20.525 T:6121910272 ERROR: Previous line repeats 1 times.
21:24:20.525 T:6121910272 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
21:24:20.526 T:6121910272 NOTICE: Creating video thread
21:24:20.526 T:6121910272 NOTICE: Opening stream: 1 source: 256
21:24:20.526 T:6121910272 NOTICE: Finding audio codec for: 86016
21:24:20.526 T:6125350912 NOTICE: running thread: video_thread
21:24:20.527 T:6121910272 NOTICE: Creating audio thread
21:24:20.527 T:6121910272 NOTICE: Opening stream: 2 source: 256
21:24:20.527 T:6121910272 ERROR: OpenStream - Unable to init overlay codec
21:24:20.527 T:6121910272 WARNING: OpenStream - Unsupported stream 2. Stream disabled.
21:24:20.527 T:6125924352 NOTICE: running thread: CDVDPlayerAudio::Process()
21:24:20.658 T:6102986752 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'OverlayHD.png'
21:24:20.689 T:6121910272 ERROR: Previous line repeats 3 times.
21:24:20.689 T:6121910272 NOTICE: Closing stream player 2
21:24:20.689 T:6121910272 NOTICE: waiting for video thread to exit
21:24:20.690 T:6125350912 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
21:24:20.690 T:6125350912 NOTICE: thread end: video_thread
21:24:20.690 T:6121910272 NOTICE: deleting video codec
21:24:20.690 T:6121910272 NOTICE: Opening stream: 0 source: 256
21:24:20.690 T:6121910272 NOTICE: Creating video codec with codec id: 28
21:24:20.690 T:6121910272 NOTICE: Open - interlaced content.
21:24:20.690 T:6121910272 NOTICE: Previous line repeats 1 times.
21:24:20.690 T:6121910272 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
21:24:20.690 T:6121910272 NOTICE: Creating video thread
21:24:20.690 T:6125350912 NOTICE: running thread: video_thread
21:24:20.705 T:6125924352 NOTICE: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through)
21:24:20.715 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
21:24:20.715 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
21:24:20.715 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.042667
21:24:20.752 T:6105853952 WARNING: AVAudioSession setActive NO failed, count 9
21:24:20.761 T:6125350912 NOTICE: fps: 50.000000, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080, colorrange: Limited, colorspace: unknown, colortransfer: unknown
21:24:20.761 T:6125350912 NOTICE: Display resolution DESKTOP : 1920x1080@ 50.00 - Full Screen (16)
21:24:20.768 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
21:24:20.768 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
21:24:20.769 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
21:24:20.769 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
21:24:20.769 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
21:24:20.769 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.042667
21:24:20.769 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
21:24:20.769 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 2
21:24:20.774 T:6102986752 NOTICE: Using GL_TEXTURE_2D
21:24:20.777 T:6102986752 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
21:24:20.781 T:6102986752 NOTICE: GL: NPOT texture support detected
21:24:21.652 T:6102986752 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'OverlayHD.png'
21:24:22.398 T:6125350912 ERROR: Previous line repeats 3 times.
21:24:22.398 T:6125350912 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
21:24:22.582 T:6125350912 WARNING: Previous line repeats 2 times.
21:24:22.582 T:6125350912 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 40000
21:24:22.630 T:6109868032 ERROR: GetDirectory - Error getting library://video/inprogressepisodes.xml/
21:24:22.654 T:6102986752 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'thumbs/OverlayWatched.png'
21:24:29.489 T:6102986752 ERROR: Previous line repeats 1 times.
21:24:29.489 T:6102986752 NOTICE: CDVDPlayer::CloseFile()
21:24:29.489 T:6102986752 NOTICE: DVDPlayer: waiting for threads to exit
21:24:29.497 T:6121910272 NOTICE: CDVDPlayer::OnExit()
21:24:29.497 T:6121910272 NOTICE: Closing stream player 1
21:24:29.497 T:6121910272 NOTICE: Waiting for audio thread to exit
21:24:29.519 T:6125924352 NOTICE: thread end: CDVDPlayerAudio::OnExit()
21:24:29.519 T:6121910272 NOTICE: Closing audio device
21:24:29.562 T:6121910272 NOTICE: Deleting audio codec
21:24:29.562 T:6121910272 NOTICE: Closing stream player 2
21:24:29.562 T:6121910272 NOTICE: waiting for video thread to exit
21:24:29.586 T:6125350912 NOTICE: thread end: video_thread
21:24:29.587 T:6121910272 NOTICE: deleting video codec
21:24:29.594 T:6102986752 NOTICE: DVDPlayer: finished waiting
21:24:29.598 T:6102986752 NOTICE: CDVDPlayer::Opening: pvr://channels/tv/All channels/pvr.hts_639350928.pvr
21:24:29.598 T:6116175872 NOTICE: Creating InputStream
21:24:29.609 T:6116175872 NOTICE: Creating Demuxer
21:24:29.609 T:6116175872 ERROR: Get - failed to get stream
21:24:29.610 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
21:24:29.610 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
21:24:29.610 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.042667
21:24:29.654 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
21:24:29.654 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
21:24:29.655 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
21:24:29.655 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
21:24:29.655 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
21:24:29.655 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.042667
21:24:29.655 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
21:24:29.655 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 2
21:24:30.422 T:6116175872 NOTICE: Opening stream: 0 source: 256
21:24:30.422 T:6116175872 NOTICE: Creating video codec with codec id: 28
21:24:30.422 T:6116175872 ERROR: CBitstreamConverter::Open avcC data too small or missing
21:24:30.423 T:6116175872 ERROR: Previous line repeats 1 times.
21:24:30.423 T:6116175872 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
21:24:30.427 T:6116175872 NOTICE: Creating video thread
21:24:30.427 T:6116175872 NOTICE: Opening stream: 1 source: 256
21:24:30.427 T:6116175872 NOTICE: Finding audio codec for: 86016
21:24:30.427 T:6121910272 NOTICE: running thread: video_thread
21:24:30.431 T:6116175872 NOTICE: Creating audio thread
21:24:30.432 T:6116175872 NOTICE: Opening stream: 3 source: 256
21:24:30.432 T:6123057152 NOTICE: running thread: CDVDPlayerAudio::Process()
21:24:30.432 T:6116175872 NOTICE: Opening stream: 2 source: 256
21:24:30.432 T:6116175872 NOTICE: CDVDMessageQueue(teletext)::WaitUntilEmpty
21:24:30.433 T:6116175872 WARNING: CDVDMessageQueue(teletext)::Put MSGQ_NOT_INITIALIZED
21:24:30.433 T:6116175872 NOTICE: waiting for teletext data thread to exit
21:24:30.435 T:6116175872 NOTICE: Creating teletext data thread
21:24:30.435 T:6123630592 NOTICE: running thread: CDVDTeletextData
21:24:30.436 T:6116175872 NOTICE: Closing stream player 1
21:24:30.436 T:6116175872 NOTICE: Waiting for audio thread to exit
21:24:30.445 T:6123057152 NOTICE: thread end: CDVDPlayerAudio::OnExit()
21:24:30.445 T:6116175872 NOTICE: Closing audio device
21:24:30.445 T:6116175872 NOTICE: Deleting audio codec
21:24:30.445 T:6116175872 NOTICE: Opening stream: 1 source: 256
21:24:30.446 T:6116175872 NOTICE: Finding audio codec for: 86016
21:24:30.449 T:6116175872 NOTICE: Creating audio thread
21:24:30.450 T:6123057152 NOTICE: running thread: CDVDPlayerAudio::Process()
21:24:30.450 T:6123057152 NOTICE: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through)
21:24:30.451 T:6116175872 NOTICE: Closing stream player 2
21:24:30.451 T:6116175872 NOTICE: waiting for video thread to exit
21:24:30.451 T:6121910272 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
21:24:30.451 T:6121910272 NOTICE: thread end: video_thread
21:24:30.452 T:6116175872 NOTICE: deleting video codec
21:24:30.453 T:6116175872 NOTICE: Opening stream: 0 source: 256
21:24:30.453 T:6116175872 NOTICE: Creating video codec with codec id: 28
21:24:30.453 T:6116175872 NOTICE: Open - interlaced content.
21:24:30.454 T:6116175872 NOTICE: Previous line repeats 1 times.
21:24:30.454 T:6116175872 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
21:24:30.455 T:6116175872 NOTICE: Creating video thread
21:24:30.455 T:6121910272 NOTICE: running thread: video_thread
21:24:30.546 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
21:24:30.546 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
21:24:30.546 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.042667
21:24:30.585 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
21:24:30.585 T:6105853952 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
21:24:30.586 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
21:24:30.586 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
21:24:30.586 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
21:24:30.586 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.042667
21:24:30.586 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
21:24:30.586 T:6105853952 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 2
21:24:30.715 T:6121910272 NOTICE: fps: 25.000000, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080, colorrange: Limited, colorspace: unknown, colortransfer: unknown
21:24:30.715 T:6121910272 NOTICE: Display resolution DESKTOP : 1920x1080@ 50.00 - Full Screen (16)
21:24:30.730 T:6102986752 NOTICE: Using GL_TEXTURE_2D
21:24:30.730 T:6102986752 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
21:24:30.731 T:6102986752 NOTICE: GL: NPOT texture support detected
21:24:32.834 T:6121910272 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 40000
21:24:36.408 T:6121910272 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
21:26:40.969 T:6116175872 WARNING: Previous line repeats 2 times.
21:26:40.969 T:6116175872 NOTICE: PVRManager - PerformChannelSwitch - switched to channel 'ABC 2'
21:26:40.969 T:6116175872 NOTICE: Creating Demuxer
21:26:41.488 T:6116175872 NOTICE: Opening stream: 0 source: 256
21:26:41.488 T:6116175872 NOTICE: Creating video codec with codec id: 2
21:26:41.488 T:6116175872 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
21:26:41.488 T:6116175872 NOTICE: Opening stream: 1 source: 256
21:26:41.488 T:6116175872 NOTICE: Finding audio codec for: 86016
21:26:41.489 T:6116175872 NOTICE: Closing stream player 3
21:26:41.489 T:6116175872 NOTICE: Opening stream: 3 source: 256
21:26:41.489 T:6116175872 NOTICE: Opening stream: 2 source: 256
21:26:41.493 T:6116175872 NOTICE: Closing stream player 1
21:26:41.493 T:6116175872 NOTICE: Waiting for audio thread to exit
21:26:41.497 T:6123057152 NOTICE: thread end: CDVDPlayerAudio::OnExit()
21:26:41.497 T:6116175872 NOTICE: Closing audio device
21:26:41.498 T:6116175872 NOTICE: Deleting audio codec
21:26:41.498 T:6116175872 NOTICE: Opening stream: 1 source: 256
21:26:41.498 T:6116175872 NOTICE: Finding audio codec for: 86016
21:26:41.499 T:6116175872 NOTICE: Creating audio thread
21:26:41.499 T:6117322752 NOTICE: running thread: CDVDPlayerAudio::Process()
21:26:41.500 T:6117322752 NOTICE: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through)
21:26:41.500 T:6116175872 NOTICE: Closing stream player 2
21:26:41.500 T:6116175872 NOTICE: waiting for video thread to exit
21:26:41.500 T:6121910272 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
21:26:41.500 T:6121910272 NOTICE: thread end: video_thread
21:26:41.501 T:6116175872 NOTICE: deleting video codec
21:26:41.501 T:6116175872 NOTICE: Opening stream: 0 source: 256
21:26:41.501 T:6116175872 NOTICE: Creating video codec with codec id: 2
21:26:41.501 T:6116175872 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
21:26:41.501 T:6116175872 NOTICE: Creating video thread
21:26:41.501 T:6120763392 NOTICE: running thread: video_thread
21:26:41.633 T:6120763392 NOTICE: fps: 25.000000, pwidth: 720, pheight: 576, dwidth: 720, dheight: 405, colorrange: Limited, colorspace: bt470bg, colortransfer: bt470bg
21:26:41.633 T:6120763392 NOTICE: Display resolution DESKTOP : 1920x1080@ 50.00 - Full Screen (16)
21:26:41.729 T:6102986752 NOTICE: Using GL_TEXTURE_2D
21:26:41.736 T:6102986752 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
21:26:41.740 T:6102986752 NOTICE: GL: NPOT texture support detected
21:26:43.165 T:6120763392 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 40000
