Movies not scraping correctly...
SuperKeeg
Post by SuperKeeg »
I am not sure if this problem is FireTV specific or not, since it is the only platform that I am using. But many of my movies are not scraping properly when trying to update my database. I am using TheMovieDB.com as tje scraper, but everything is just scraping... wrong. The files are in the correct format with release year. They should be scraping properly. But even trying to manually refresh the data, sometimes it just gives me either the wrong data or nothing is at all available. I have tried scraping on two different FireTV's (Cube and 4k Stick). I am unsure if it is the extension, the website, or MrMC itself. I really don't want to have to refresh the entire database using a different scraper, too.
Thanks!
Gertgerman
Re: Movies not scraping correctly...
Post by Gertgerman »
I had the same problem on my Apple TV 4K and was advised to sign up for the test flight beta version. Since then it’s working perfectly. I don’t have the link for the test flight Thread but have a look and see if it also applies to the firestick app.
lgcardwell
Post by lgcardwell »
I am finding the same problem on Nvidia Shield. Tried
changing the scraper in settings but it doesn't allow that.
Upside-down
Post by Upside-down »
Yeh, The MovieDB updated something recently. I switched to the Universal Movie Scraper and that works.
See discussion here:
https://forum.kodi.tv/showthread.php?tid=347227
