Hello,
i've an issue with my database. I've got kodi on all my other devices, i can play all my medias.
He are step i done.
1) connect mrmc to my sql database
as it is not the same version i copied my current video database as "MyVideos107".
my medias are visible on mrmc (great !!!)
2) i create path to medias with user and password info
i can browse my files, and play them !!!
-- here is the bug --
3) when i pick video from my medias i've got an error message (as i'm french i'll try to translate it as well as possible) "remove file ? this fille don't longer available. shall we remove it from medias ?"
for record the my trick worked as long as kodi won't be update to the last version (18). My protocol acces is sftp and for some devices i'de to copy .ssh folder on to kodi root directory but we can't reach it on atv.
i've got some advice ?
thank you.
sftp issue
Re: sftp issue
What does the debuglog have?
v38france
Re: sftp issue
hello,
I can't access to the debug log
I've got the message "Log not uploaded"
I tried to reset log config.
thank for your help
thank for your help
v38france
Re: sftp issue
hello i'd to uninstall/reinstall mrmc to may logging.
here is my log : DGZLA.log
thanksv
thanksv
Re: sftp issue
GetDirectory - Error getting sftp://USERNAME:[email protected]/
17:22:19.648 T:6162853888 ERROR: SFTPSession: Failed to connect 'Connection refused'
You sure that’s the correct host address? Your movies in database have a different one
Set the user/pass for correct host and it might work... I only see issues with connection refused and being unable to connect to video share
v38france
Re: sftp issue
Hi, i've remake my configuration : same issue B51QC.log
Re: sftp issue
You didn’t remake it good
20:35:13.856 T:6168358912 ERROR: SFTPSession: No authentication method successful
20:35:13.857 T:6168358912 ERROR: SFTPSession: Not connected, can't list directory ''
20:35:13.857 T:6168358912 ERROR: GetDirectory - Error getting sftp://[email protected]:3113/
