Unable to setup Hue connection
rahalb
Post by rahalb »
I'm attempting to setup my hue bridge to use with the ambilight feature. Im on TVOS 12.4, and latest version of MrMC.
When I attempt to connect my hue bridge under Hue Client--> hue bridge pairing--> pair, the screen becomes frozen at 0% and pressing the connect button on the bridge makes no difference. I eventually have to quit the app because it is unresponsive. This feature had previously worked well but I had recently updated my appletv firmware to 12.4.
If there's any advice you guys can give, I'd appreciate it! Thanks!
rahalb
Re: Unable to setup Hue connection
Post by rahalb »
Spoke too soon. Did a hard reset of my Apple TV and it solved the issue. Thanks!
ALFoMan
Post by ALFoMan »
ALFoMan wrote: 19 Sep 2019, 12:09 How about this ? :
has nothing to do with MrMC and it doesn't require any software to run, how is that relevant?
Jarvismeier
Post by Jarvismeier »
https://www2.meethue.com/en-us/p/hue-hd ... 6677555221
Doesn’t support Dolby vision and also costs more than an Apple TV.
kamil66
Post by kamil66 »
Bravo HUE avec MRMC fonctionne bien
