No subtitle is found, ever
bias_hjorth
Post by bias_hjorth »
Hi MrMC forum
Perhaps you can help me with a question. I recently bought the app and loving it so far although I took me heaps to discover how to enable Atmos sound within the app (Using the Nvidia Shield) - Long story short Expert mode and then tell the app that my receiver supports it.
My question is, the app never finds any subtitle even if I search for a manual string with a generic string like Hobbit, Agent or something really simple. I created a user on both Opensubtitles and Podnapisi but neither did anything better eventhough I'm currently using username and password for Opensubtitles within the app.
The app simply tells me "searching for subtitles" and then after a couple of minutes "No subtitle was found".
What am I doing wrong?
Re: No subtitle is found, ever
subtitles work here just fine, I use them daily.
could you pull a debuglog please for us to try to find something in it
bias_hjorth
Thank you for the quick reply.
I don't know what happened other than I've in the meantime switched ISP to get gigabit internet and hooked the Shield up via cable. Now it finds subtitles instantly. I wonder if my old router was blocking it somehow. Either way problem ix fixed.
Thanks again
