Can TvOS or MrMC encode DTS5.1 to DD5.1 on the fly?
aaaMMMaaa
Post by aaaMMMaaa »
Hello.
I want to give a ATV4K as a present to my brother, but there is something im in doubt about.
His current setup
Video: RPI 3b -> ViewHD 1080p hdmi splitter -> HDMI -> TV
Audio: -> Toslink SPDIF -> Reciever (does NOT support HDMI input, only toslink/spdif input)
In this way, he has support of passtrhough of DTS5.1 and DD5.1 (AC3)
I understand that TvOS since 11.3 does NOT support passthough.
Therefore i think it will be impossible to support DTS5.1 without transcoding.
What is the best way forward, as I believe it is impossible to get bitstream DTS5.1 as was the case with RPi?
Running MrMC (latest) on Atv4K-TvOS (latest)
aaaMMMaaa
Re: Can TvOS or MrMC encode DTS5.1 to DD5.1 on the fly?
Post by aaaMMMaaa »
No one can assist with my question? No one has a similar setup?
What does people do that have an old working reciever which works perfect with DTS5.1 and DD5.1 via optical and that has an apple TV? I thought the solution would be trivial, but perhaps not?
What does TvOS do, when it recieves a DTS stream from MrMC, and the Audio out is set to Dolby Digital?
Does it transcode it to DD5.1 or DD2.0?
How does MrMC send the DTS stream to TvOS? Does it send it natively, or does it decode it to 5.1PCM, and then TvOS encodes to DD5.1?
Someone must know the answer to these questions?
Post by cosmoxl »
You'll have to give people time. They're busy with lives or working on development.
I'm unfamiliar with your situation but I believe MrMC can still encode to DD 5.1 if setup that way. Or you can have MrMC just output PCM (that's the default, all you'd need to do is set the proper number of audio channels) and set tvOS settings to output DD 5.1 and not "best available" which is multi channel PCM.
MrMC set to 5.1 pcm -> Apple TV setup to DD output will output 5.1 DD , I cannot comment on Toslink SPDIF conversion and how well that will work from Apple TV, depends how tv( or however you convert) handles that
aaaMMMaaa
Post by aaaMMMaaa »
For anyone finding this thread in the future.
I simulated that my soundbar could only do 5.1 DD, as to simulate Toslink/spdif recieving end.
I changed the TvOS to convert audio, and choose DD.
In MrMC you have to choose 5.1 in audio channels.
I then tried playing DTS, DTS-HD, TrueHD etc.. And all seemed to convert to DD5.1, when looking into my reciever. So this is very good news for anyone looking for same question as me.
