MrMC crashes during TV Scraper Scan
toastie
Post by toastie »
Hey everyone,
since today my MrMC App is crashing on my AppleTV 4K when the scan for TV Series is starting. I rebooted the AppleTV, reinstalled the MrMC App but none of this is helping. Any thoughts what this could be? I'm using the TVDB scraper for the scan. Does anybody else have the same problem?
toastie
update:
I can definatively confirm that it is related to the TVDB scraper. When I'm using the MovieDB scraper everything is working properly. As soon as I switch again and do a rescan, the App is crashing.
Montoya
Re: MrMC crashes during TV Scraper Scan
Post by Montoya »
There is an API change of TVDB, which appears to have trouble now with backwards compatibility of API requests it seems. So maybe MrMC is crashing because of that...
toastie
Post by toastie »
That would explain it at least but why is it only happening to me? I have the newest version installed and a friend of mine doesn't see that issue.
Montoya
Post by Montoya »
toastie wrote: 02 Aug 2019, 20:35 but why is it only happening to me?
You can only draw that conclusion if you are both scraping the SAME TV Shows and episodes, using the exact SAME software, configured the same way.
Story short, TVDB seems to have issues now, due to all the changes they have done recently.
toastie
Post by toastie »
Well, then I'll be patient and wait for a fix. Workaround is in place so I'm fine. Thanks for your explanations and input!
https://forums.thetvdb.com/viewtopic.php?f=118&t=57711
The short, tvdb rolled out a new 'defective' API. Just about every app that uses them is having issue including crashing.
The details have been investigated and it's a major 'opps' on the part of tvdb. They are rolling back to the previous API.
ensignvorik
Post by ensignvorik »
I see they are in no rush to fix this. As if Tvdb rep wasn’t in the gutter enough with me already.
ensignvorik
davilla wrote: 03 Aug 2019, 19:15 https://forums.thetvdb.com/viewtopic.php?f=118&t=57711
it looks like the kodi tvdb scraper has been updated to v3.0.16 as my mrmc version is at 2.0.16 I assume this requires an app update as we aren’t able to manually update it. Any idea of an eta? Having to keep my new shows outside my scraping folder for the time being to prevent crashes. I’d rather not switch scraper entirely if possible.
tvdb crash issue fixed in TF for 3.9
moonrak
Post by moonrak »
When will v 3.9 be released to the App Store?
Carlos
