Just installed using the Ariana skin (have also tested with the Opacity skin) with Emby - and annoyingly the Library folders are showing in reverse alphabetical folder on the main menu. Is there an obvious fix for this that I'm missing?
Cheers
M
Emby Integration - Library folders in reverse order
Re: Emby Integration - Library folders in reverse order
slide left, change the sort order.matfid wrote: 14 Jul 2019, 16:20 Hi,
Cheers
M
- Montoya
Where is that feature hidden in all Skins, to change the sort order of Emby libraries on MrMC Home Screen ?davilla wrote: 14 Jul 2019, 16:28slide left, change the sort order.matfid wrote: 14 Jul 2019, 16:20 Hi,
Cheers
M
Is that device specific ?
In "Movies' or 'TV Shows', sort is control by the skin, aka left side out in opacity.Montoya wrote: 14 Jul 2019, 17:04Where is that feature hidden in all Skins, to change the sort order of Emby libraries on MrMC Home Screen ?davilla wrote: 14 Jul 2019, 16:28slide left, change the sort order.matfid wrote: 14 Jul 2019, 16:20 Hi,
Cheers
M
I'm really not sure what 'Library folders are showing in reverse alphabetical folder on the main menu' really means.
The main menu is home and library folders have nothing to do with what shows on main, what shows up are 'recently added' or 'in progress' or some other choice.
matfid
I'm talking about the Emby library folders that appear as top nav in Ariana, or left nav in opacity. They appear in reverse alphabetical order i.e. instead of Action, Comedy, Drama - they appear as Drama, Comedy, Action. Which is the opposite of the sort order I have set in Emby Server.
There is no option to 'slide left' on the main menu, so sort order can't be changed that way (it can if I am inside a library, but not on the main menu).
M
M
- Montoya
As far as I can remember, there was never a "left side out in Opacity" (or in any other MrMC Skin), specifically for the "Sort Order" of the Multiple Emby libraries shown in left column of MrMC Home Screen WHEN an Emby Server is chosen as MrMC Server "SOURCE", with the Emby Client Servicedavilla wrote: 14 Jul 2019, 18:25In "Movies' or 'TV Shows', sort is control by the skin, aka left side out in opacity.
Library sections on home are not sortable, it’s dictated by emby/plex server
- Montoya
And now we are back to topic start, that MrMC shows them in reverse alphabetical order, for the Emby Client Service for quite some MrMC revisions alreadyamet wrote: 14 Jul 2019, 20:05 Library sections on home are not sortable, it’s dictated by emby/plex server
I’ll check it
- Montoya
To me, this applies when having multiple Emby Movie Libraries.
Don't know if it also applies when having multiple Emby TV Show libraries (don't have those in multiples).
