Just go to https://play.google.com/apps/testing/tv.mrmc.mrmc to join/leave testing.
- koying
I'll post a beta in ~24h, so now is a good time to leave beta from google play if you don't want to be a tester anymore
Ghostm
Hmm this version installed and its stuck on a screen that just say's waiting for service?
Ghostm
Actually after unplugging the shield and trying to relaunch, i just get a black screen.
- koying
You know the drill, debuglog , please
Audiomixer
Is there a changelog for 3.9.0 over 3.8.1?
Going to play with it this afternoon.
Audiomixer
One problem is that plex addon will no longer auto start. I get the “plex error, check the log for more information.” It will start after MrMC is up and running via the extensions tab.
What I have tried. Cleared all data and cache to start over. No change. Uninstalled MrMC and reinstall from google play store and reconfigure. No change. Used the default skin, no change.
Log below.
https://pastebin.com/fNXud9nA
Log below.
MrMC never starts up for me. Just stays black screen after initial splash.
https://paste2.org/7pLmCjM7
Audiomixer
No problem starting up here. Even tv show sorting is correct now outside of any plex environment.
Did you uninstall and then reinstall the app and start over?
- koying
Would the ones being stuck use Airplay / Airtune ?
Fehritale
I also get a black screen after the starting screen.
And no I don't use Airplay/Airtune.
debuglog can be found here https://pastebin.com/psDhjhPU
