Hallo,
the recording playback currently does not work with the actual version.
Kind regards
Falcon83
VU+ PVR Addon
Re: VU+ PVR Addon
Could you get the debuglog of the playback failing please
Falcon83
Re: VU+ PVR Addon
In the following the important part of the log (ip address removed):
20:46:37.852 T:368013184864 DEBUG: Previous line repeats 1 times.
20:46:37.853 T:368013184864 DEBUG: Keyboard: scancode: 0x17, sym: 0x000d, unicode: 0x0000, modifier: 0x0
20:46:38.013 T:368013184864 DEBUG: OnKey: return (0xf00d) pressed, action is Select
20:46:38.085 T:368013184864 DEBUG: CCurlFile::GetMimeType -
20:46:38.162 T:368013184864 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
20:46:38.163 T:368013184864 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: streams
20:46:38.168 T:368013184864 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
20:46:38.168 T:368013184864 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
20:46:38.168 T:368013184864 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
20:46:38.168 T:368013184864 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
20:46:38.168 T:368013184864 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
20:46:38.177 T:368013184864 NOTICE: CDVDPlayer::Opening:
20:46:38.177 T:368013184864 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:46:38.204 T:368013184864 DEBUG: CCurlFile::GetMimeType - s -> video/MP2T
20:46:38.205 T:368079161488 NOTICE: Creating InputStream
20:46:38.206 T:368079161488 DEBUG: CurlFile::Open(0x7f63823278)
20:46:38.250 T:368079161488 DEBUG: CFileCache::Open - opening <file> using cache
20:46:38.251 T:368079161488 DEBUG: CurlFile::Open(0x55b048daf0)
20:46:38.280 T:368079161488 NOTICE: Creating Demuxer
20:46:38.281 T:368079161488 DEBUG: Open - m_ioContext->max_packet_size(1) = 0
20:46:38.297 T:368079161488 DEBUG: Open - avformat_find_stream_info starting
20:46:38.332 T:368079161488 ERROR: ffmpeg[55B33A4890]: [h264] SPS unavailable in decode_picture_timing
20:46:38.333 T:368079161488 ERROR: ffmpeg[55B33A4890]: [h264] non-existing PPS 0 referenced
20:46:38.333 T:368079161488 ERROR: ffmpeg[55B33A4890]: [h264] SPS unavailable in decode_picture_timing
20:46:38.334 T:368079161488 ERROR: ffmpeg[55B33A4890]: [h264] non-existing PPS 0 referenced
20:46:38.335 T:368079161488 ERROR: ffmpeg[55B33A4890]: [h264] decode_slice_header error
20:46:38.335 T:368079161488 ERROR: ffmpeg[55B33A4890]: [h264] no frame!
20:46:38.335 T:368079161488 ERROR: ffmpeg[55B33A4890]: [h264] SPS unavailable in decode_picture_timing
Re: VU+ PVR Addon
We do need to see the full log if you don’t mind, it has much more info that we can use
Falcon83
Re: VU+ PVR Addon
Hello Amet,
On the FireTV I have switched to Kodi 18.1 Final with the Enigma PVR Plug-In where the recordings playback works fine again.
Kind regards,
Mark
Kind regards,
Mark
