I have a FireTV 1 trying to stream from a DS716plusii using NFS. I keep getting video playback problems that I can't repeat consistently. I created a debug log here:
https://1drv.ms/t/s!AjlFvM-kUCwhgP9Olqj9-ip9_-44_g
The first video played without any drops. The second one started having issues. I paused the video and captured the log at that point.
Video stops and starts using FireTV 1
GPinzone
Re: Video stops and starts using FireTV 1
I noticed the buffer isn't being filled. It says "forward: 0B 100%" Where the 100% fluctuates. It's 150MB on my other Fire TV. I created a connection via UPNP and it uses a 150MB buffer.
chrisc2r
Hello,
I'm getting exactly the same symptoms on my Firestick - The first video to play is typically fine and buffers normally and playback is normal.
Then, a subsequent one does not: C(a/v: (between about -0.05 and +0.05), edt:-, ad:0.000, forward: 0 B 100% 0 sec)
and playback stutters occasionally while watching.
The firestick is hard wired to a Western Digital NAS over gigabit LAN, and the videos are standard definition mkv rips from my own DVDs using h264 at about 1GB per hour.
I've uploaded IWHKO.log
The first and second movies I played correctly filled the log file, while the third I played did not
Any help would be gratefully received
thanks
Chris
thanks
Chris
