Cleaning library doesn't finish
heddhunter
Post by heddhunter »
I've tried several times but cleaning the library just doesn't do anything. It sits on the cleaning screen (Opacity skin) with the spinner not spinning, and that's it. I've let it sit there for hours. I can cancel out of it but that's all.
Attempting to play a removed item does give me the "item not found, would you like to remove it from the library" prompt, and this does work, but trying to find everything one at a time to do that is a real bummer.
Any ideas?
Re: Cleaning library doesn't finish
heddhunter wrote: 17 Apr 2019, 19:05 I've tried several times but cleaning the library just doesn't do anything. It sits on the cleaning screen (Opacity skin) with the spinner not spinning, and that's it. I've let it sit there for hours. I can cancel out of it but that's all.
Any ideas?
debuglog please.
heddhunter
https://pastebin.com/z87gmeVH
After a quick look at the log, I have a feeling it's getting hung up on DNS for a machine that no longer exists ("GLADOS"). Unfortunately after a while it seems to hang MrMC completely. The only way out is to force quit the app.
