Hi. Since the new 8.1 release I can no longer use MrMC. I have an Nvidia Shield and also Sony Android TV both running Android Oreo. I add Plex as a media source and it appears to register. I never get connected. If I go to sources, it gives me option to sign out of Plex so it thinks it is connected, but isnt. I only have media source and quit to select from on home screen. This used to work fine on previous versions. Any ideas?
Cannot use MrMC 8.1 with Plex on Android TV
Re: Cannot use MrMC 8.1 with Plex on Android TV
I assume you mean 3.8.1 beta test as there's no release yet. You probably just need to go up to the top little icon that looks like 3 stacked hard drives and probably says MrMC underneath it, click that, and choose your plex server.sjm817 wrote: 26 Mar 2019, 14:43 Hi. Since the new 8.1 release I can no longer use MrMC. I have an Nvidia Shield and also Sony Android TV both running Android Oreo. I add Plex as a media source and it appears to register. I never get connected. If I go to sources, it gives me option to sign out of Plex so it thinks it is connected, but isnt. I only have media source and quit to select from on home screen. This used to work fine on previous versions. Any ideas?
sjm817
I tied that. The only server it shows is "MrMC" It does not show my Plex server. When I first launch MrMC an error pops up saying it cannot connect to Plex server.
sjm817
Yes, seem that’s the issue.
You will need to go back to 3.8.0 until new 3.8.1 is done
sjm817
I am back to 3.8.0 and all is well. Thanks!
