Browse photos left/right on remote not working?
Harnos
Post by Harnos »
To bring up the next or previous photos by left/right on remote not working in last release, hope you can bring that function back again, thanks.
Re: Browse photos left/right on remote not working?
Swipe left/right? Or tap left right ? Which remote?
Debuglog please while it fails
Harnos
Post by Harnos »
ATV4 remote swipe and tap, ATV3 remote tap, Samsung TV remote tap - nothing works for me in this version, previous version all of my remotes worked to browse pictures/photos this way.
it works here just fine, slideshow goes forward/back on swipe and on tap... debuglog maybe? did you change your keymap by any chance?
Harnos
Post by Harnos »
Not changed anything to my knowledge else than that the version was upgraded and had to choose a different skin.
This has happened a few times in the past too but is usually ok after one/two updates/upgrades so will wait and see.
Its definitely working here, what skin are you using and maybe post a debuglog?we can maybe pick something up in there
Harnos
Post by Harnos »
Don't remember the name now but can check when I’m home again.
I see you wrote slideshow, that is not what I'm doing, I navigate to one of the folders with photos, then open the first one in there and have in the past used the left/right tap to browse my pictures.
That is what we call a slideshow, it displays the picture in full screen and you can go left/right for next and previous photo in the folder
That is working fine for me here, so let’s see the debuglog to try and find out what is wrong on your end.
Harnos
Post by Harnos »
Did some more testing today, it does work if I use skins = Black Glass Nova or Opacity, does not work if I use skin = Amber or Ariana.
I using Amber skin and would like to continue doing so, does this work for anyone using Amber skin?
It is browsing pictures in full window I'm trying to do, when pics are in smaller pre-view size it does work but not in full window mode.
Thanks!
Harnos
Post by Harnos »
