3.7.1 gone from bad to worse
Alpaca
Post by Alpaca »
Today, I gave the long awaited bug fix release a try on my 2nd gen. FireTV. Unfortunately, after waiting for more than three months for a fix of the audio sync problem the situation is worse than before. Not only is audio still out of sync after a couple of minutes but now I also have video stuttering which I didn’t have before. Reverting back to standard settings for audio and video didn’t help!
eXiNFeRiS
Re: 3.7.1 gone from bad to worse
Post by eXiNFeRiS »
Same Problem here. In this form MRMC is worthless. :(
Well, your debuglog shows... oh, no debuglog. Sorry can't help.
eXiNFeRiS
Post by eXiNFeRiS »
I use now SPMC. Works fine. :)
Alpaca
Post by Alpaca »
Scanning ...
davilla wrote: 07 Jan 2019, 22:59 Well, your debuglog shows... oh, no debuglog. Sorry can't help.
Arrogance level 9/10 detected! :(
Here's the log: https://we.tl/t-oo3lYM6bF5 Couldn't use pastebin because of the size even though I already took out the scanning part. While audio went out of sync after a couple of minutes video was fine this time.
eXiNFeRiS
Post by eXiNFeRiS »
Alpaca wrote: 07 Jan 2019, 21:01 Today, I gave the long awaited bug fix release a try on my 2nd gen. FireTV. Unfortunately, after waiting for more than three months for a fix of the audio sync problem the situation is worse than before. Not only is audio still out of sync after a couple of minutes but now I also have video stuttering which I didn’t have before. Reverting back to standard settings for audio and video didn’t help!
Try to disable Vertical-Blank-Synchronisation in System Video Options.
Alpaca
Post by Alpaca »
Unfortunately, that is even worse. Takes less than a minute before video starts stuttering and audio goes out of sync.
eXiNFeRiS
Post by eXiNFeRiS »
In my case it fixed The Problem.
Alpaca wrote: 10 Jan 2019, 19:41 Unfortunately, that is even worse. Takes less than a minute before video starts stuttering and audio goes out of sync.
try something other than an h256 encoded video
Alpaca
Post by Alpaca »
Let’s assume h264 works, how does that help with h265? By now, most of my videos are encoded with h265. And MrMC 3.6.0 worked like a charm. Something obviously was broken with the introduction of 3.7.0/1.
