Thanks for your work on development of MrMC. I've bought your app on my Android TV (Android 7, 55POS9002 Philips) however I have one major issue.
SPMC 16.7.4
23.976 - WORKS OK
25 fps - WORKS OK
29.976 fps - DROPS FRAMES
60 fps - DROPS FRAMES.
MrMC 3.7.0
23.976 - DROPS FRAMES.
25 fps - DROPS FRAMES.
I'm using MediaCodec Surface to render as hardware is not powerful enough to use MediaCodec only. I've tried different settings with sync playback to display - still same issue.
Is there something we can do about it? I can post sample files and of course debug logs, but what log do you need? MrMC only or also logs from SPMC to see what's happening under the hood? Please help me.
Greetings
