I picked up MrMC for IOS this morning to use on my iPhone 6S while I worked in the kitchen. I got it connected to my MythTV installation, but I'm not getting any audio when watching LiveTV or recorded TV. Audio works with the same files on MrMC for tvOS. I do get audio in MrMC for IOS when I'm connected to a SAMBA share with video files in it.
The recordings are done with a HDHomerun Prime, so they should be pretty standard files. Am I missing something?
MythTV PVR Playback on MrMC for iOS
Re: MythTV PVR Playback on MrMC for iOS
not unless its dts/ac3 and you are in US, move to Canada in that case
ptaylor
Strangely enough, when I start playing back a video and bring up the OSD, next to the speaker icon it says "spa", making me think it's set for the spanish audio track. If I hit the audio settings icon, I see that indeed it does have the Spanish track selected. I can select the english track, but nothing changes. Next time I come back to that screen, it still shows Spanish selected. Again, it doesn't matter as I don't have any audio playing no matter what... When using the MythTV PVR.. Other files play back fine... (And MythTV plays fine on MrMC on tvOS)
sounds like english is ac3 and that can be disabled depending on timezone for iOS. AC3 is always enabled under tvOS.
ptaylor
Ok, I downloaded the file from MythTV (via the web interface) and the properties show the codecs as MPEG2 and AC3...
You say it can be disabled depending on timezone for iOS? Apple disables it based on timezone? Any way to fix it?
Like I said, move to Canada .... Or just change the timezone to Canada
ptaylor
EH-yuh! Beauty!
What hoser came up with the idea to restrict AC3 like this?
US Patent Lawsptaylor wrote:EH-yuh! Beauty!
skyandsea
My kitchen TV broke down several days ago and I plan to buy a new TV for my kitchen from this website:15 inch tv https://gecey.com/. I want to install the MrMc in this TV , but I have not any experience. So, is the MRMC can be install in any TVs with the android system?
Only ones that support google play.skyandsea wrote: 23 Jan 2019, 02:59 My kitchen TV broke down several days ago and I plan to buy a new TV for my kitchen from this website:15 inch tv https://gecey.com/. I want to install the MrMc in this TV , but I have not any experience. So, is the MRMC can be install in any TVs with the android system?
