Hi
I am experiencing a problem that I can see somebody also had over a year ago, but I cannot see if he really found a solution. My problem is that I am using the mrMC APP on my apple tv and suddenly opensubtitles have stopped working - or is basically tells that there is no subtitles to download, up until 8 or 9 months ago it worked fine and then from one day to another it stopped. I have tried to delete mrMC from the device and after that re-installed everything again but that didn't help.
I there a solution to my problem ?
Thanks in advance
Jens
Issue with OpenSubtitle
Re: Issue with OpenSubtitle
There are some issues in Denmark, I believe ISPs are blocking the api but not the main site.
If you are there, try setting dns servers to 8.8.8.8 or opendns, that helped.
If not, let’s see the debuglog... opensubtitles works fine, I have just used it although it does have some issues with servers overloading sometimes
jmodgaard
Thank you very much
Changing the DNS helped right away
Br
Jens
Br
Jens
