timstephens24 wrote: 25 Mar 2018, 19:46 Tried out the iPad version and the Plex addon is not very great on a touch screen (you called it @davilla lol). Scrolling the main screen is difficult, as it seems it doesn't exist and it just goes to where you touch. Scrolling the movies and tv section seems to actually work as gesture scrolling. The posters are truncated, so for example the poster for Anchorman shows "nchorma"
I also have no idea how to get back to the default Opacity screen when in the Plex addon.
Edit: seems the touch areas in the Plex addon settings overlap or are off. I have to touch a little above where I feel I should be touching to change settings.
Plex addon under IOS
- timstephens24
Re: Plex addon under IOS
Anything in this upcoming release for the iPad?
touch handling was tweaked. a testflight version is waiting beta review.
- Everbrave
In the TestFlight:
- The aspect ratio is still not correct; elongated in the vertical direction.
- touch control is also still erratic; swiping to the left causes the rows to scroll vertically
P.S. do you want this feedback here or in the TestFlight thread (which is almost exclusively about tvOS)?
EDIT: in its current state, I’d say, I won’t use the add-on on iOS but rather the native Plex app.
