Advanced Wake on Lan / Unpause Jumpback
danielxb
Post by danielxb »
Now that plex for kodi will come to mrmc, will you add this 2 addons ? Advanced WOL is the only solution to send a magic packet to wake up a server, Unpause jumpback... is amazing... (basically, rewind a couple of seconds after x time of pause (for example to not cut dialogs)
Sorry for my english, i'm from argentina
Re: Advanced Wake on Lan / Unpause Jumpback
what is Advanced WOL, we already support WOL
danielxb
Post by danielxb »
Advanced WOL send a Magic Packet (In windows you can set that only a magic packet wake up the pc, based on mac address), Here, the microsoft explanation: https://support.microsoft.com/en-us/hel ... n-lan-feat
Yes, I know what WOL is, as mentioned. MrMC already supports that.
danielxb
Post by danielxb »
Well, i tried this weekend and MrMc does not wake up my plex server, but SPMC with Advanced Wake On Lan does it fine, i can't find in MrMc where to put the mac address of my server.
Settings -> System -> Power savings -> "Try to wakeup remote servers on access"
change settings to expert.
This will look at all remote servers (including plex/emby) and set them up for WOL.
danielxb
Post by danielxb »
It's chequed, but only works if i deselect the "only allow a magic packet to wake this computer", but in that case, turning on any pc on the net, wake up the plex server (maby the plex live tile, i don't know)
danielxb
Post by danielxb »
Sorry, the "only allow a magic packet to wake this computer" is on device manager, lan card, power options, windows 10
Trunks78
Post by Trunks78 »
+1 for Unpause Jumpback Add-on request
Perlbo
Post by Perlbo »
my TV Server does not run 24/7 so i want to wake it up, when I use it. WOL don't function for LIVE TV with mrmc. And I don´t the a option to wake up the server within MRMC.
With Kodi I map WOL with Key and I can start the Server with Keypress, when I want...
Would something like that possible with mrmc ?
