Hello,
I'm using MrMC with DVBLink PVR.
With the last update I can't schedule a recording. When I go to EPG and select add recording a new screen is poping up and asking about "serial recording settings" and MrMC is freezing with the screen. There is input possible.
I have to restart AppleTV.
This is since the last update of MrMC.
Is there a solution for this?
MrMc is freezing when try schedule recording
Re: MrMc is freezing when try schedule recording
which version worked ?
Xilinxs
Version 1.1.0
I think in Version 1.2.0 was also an update of the DVBLink Add-on, may that cause the problem?
Xilinxs
Hello,
any update on this?
Will this be fixed in the next update?
Thank you very much.
any update on this?
three6zerocool
Same thing is happening to me. Gui freezes in the scheduling screen. Is as tho the cursor navigation controls stop working. ie. Can not navigate down to confirm the recording.
Am using MediaPortal backend, and it was working with first MrMC release, so the issue would appear to be with the current release version of MrMC, as I think the MediaPortal PVR addon is same version?.
Anyway, MrMC is now crippled to me, as ain't a PVR anymore. 'Bummer'
Xilinxs
New Update today, but still the same issue.
Is there any update on this?
Is there any workaround to fix this?
This will get fixed in next update.Xilinxs wrote:New Update today, but still the same issue.
Xilinxs
Hello,
any update on this issue?
I just installed the update from today and it is still not working?
When will this be fixed?
Xilinxs
... just an update on the behavior:
After you go on "add timer" there is new message coming up,
asking you about record this program and after the series timer is coming, which crash MrMC!!!
Hockney
I have same issue with NextPVR backend...very interested in timeline for fix.
Thanks..
Thanks..
