Hi, since the Update to 1.2 i am not able to passthrough dts sound. In the prev. Version it was no problem.
I have the same settings (passthrough and dts receiver checked).
Anybody with the same problem or is there a solution?
DTS Problem with MrMc 1.2
Re: DTS Problem with MrMc 1.2
Nothing was changed regarding DTS. When you say you can't enabled it, does that mean;
a) there is no setting to enable ?
b) the setting does not stick ?
c) the setting is enabled but you do not get dts passthough ?
verify the video does indeed have a DTS audio stream -> OSD -> audio
mrmc.log if it still has issues.
zuzumuzu
Hi thank you for your answer,
Ok its getting stranger. Video dts is no problem. But it wont play music dts. In the prev version it was no problem to play music files with dts. I tried the same files (yes i am sure they are dts)
The setting is still there.
The setting doesnt stick.
The setting is enabled (it has to be, otherwise it wouldnt play the video dts)
Now i tried many options, without succses (video dts ok. Music dts no)
which previous version worked and can I get a sample music dts to debug with ?
zuzumuzu
Yes sure. How i can send you the file?
The version where the music dts worked fine was 1.1!
zuzumuzu
I sent you the dropbox link
