Trouble loading channels from Infusum.tv using Simple client PVR
steinaratli
Post by steinaratli »
Hi and thanks so much for this awesome app
I have a question regarding streaming channels from Infusum.tv using MrMC on Apple TV4.
I'm using Simple client in PVR IPTV and bought a subscribtion with Infusum.tv, they told me that this should work and sent me instructions that I followed step by step and I have double checked every step of the instructions. (See instructions below) It looks great and the system loads all the channels to the channel list, logos for channels and the EPG but I can't view any channel. When I click a channel, for example SkySports1 the little notification box that usually says "Working..." doesn't appear. I downloaded tvMC {removed links} and connected the Infusum subscription using the same instructions and it worked. Does anyone have any idea what could be the problem?
I also tried using GES Smart IPTV on AppleTV4 and that app can stream this list of channels from Infusum.tv but I would like to use MrMC instead, the UI is alot nicer!
Please help :)
Best regards,
Steinar
INSTALLATION INSTRUCTIONS FOR ALL XBMC/KODI DEVICES: PLEASE NOTE WE USE IPTV SIMPLE PVR WHICH COMES PRE INSTALLED ON ALL XBMC/KODI VERSIONS
{removed links}
IPTV SIMPLE PVR SET UP INSTRUCTIONS:
We have recently developed a new method for viewing infusum on your device by using the XBMC/KODI pre installed Addon called "PVR IPTV Simple Client" and your own unique m3u list.
Please find instructions below for installing your subscription details using this method, the instructions are the same across all devices and all versions of Kodi/xbmc
If you are currently using infusum with our own in house developed plug in called infusm.tv PVR then you have to disable that first before enabling the simple PVR. (if you dont have Infusum PVR skip this step and go to next step) To disable Infusum PVR go to:
System (or settings) on the main section then: addons, enabled Addons, PVR Clients, infusum.tv-PVR and select it.
Click on Disable. You will then see a message that says "NO PVR ADD-ON ENABLED" Just click ok
HOW TO CONFIGURE "PVR IPTV Simple Client" FOR USE WITH INFUSUM
1.Press return button to go back to main section and then press System (or settings)-disabled addons then move down the list and locate "PVR IPTV Simple Client" and select it. Move up to Configure button press it and then put in your details:
Under General-move across to the M3U Playlist URL and select it. Put in your M3U Url shown here:
{removed links}
Click done
Move over the EPG Settings on the left and then to the XML TV URL on the right, select it and put in these details
{removed links}
Click Done
Move over the Channels Logos Settings on the left and then to the Channels Logos Base URL on the right, select it and put in these details
{removed links}
Click Done
Move to the right and select OK
Move down to "Enable" and click it
You should get a message that the channels are loading, if you do not there may be a bug in Kodi that prevents this from happening, if so do this:
Press the return Button, go to settings-Live TV-Make sure its enabled (on the top right it will be selected) go down the menu until you see EITHER "reset the pvr database" OR "Reset data" and select it, click Yes. You may get a message saying "No PVR Addon Enabled" if you do go back to
settings-addons-disabled addons-find PVR IPTV Simple Client and click enable.
You may have to click enable a few times until you see the channels and EPG info loading across the top, this is a bug in Kodi and nothing to do with us. Once its enabled and channels have loaded quit Kodi and restart, the channels should load then all the time.
PLEASE NOTE: THERE IS A BUG IN SIMPLE IPTV CLIENT THAT MEANS SOME EPG DATA WILL NOT BE AVAILABLE UNTIL AFTER 11PM ON THE DAY YOU INSTALL IT. AFTER THAT TIME ALL EPG DATA WILL POPULATE THE CHANNELS.
joshy123
Re: Trouble loading channels from Infusum.tv using Simple client PVR
Post by joshy123 »
Will not work, MrMC has removed rtmp which is required to play these streams, also illegal addons like these are not allowed to be discussed here
what @joshy123 said...
removed all links...
