Where is the right area?davilla wrote: 11 Feb 2019, 22:06more like you are not looking in the right areasirmcftv wrote: 11 Feb 2019, 16:55 I'm seeing the same issue on the FireTV Stick 4K, video and audio are out of sync. I installed Kodi 18 and it seems to work well, so it is possible. Plex client also works, so not sure it's the new stick.
I initially bought MrMC (a few times on different accounts) to solve problems I used to have with Kodi, which it did. But now the situation seems to be reversed, it feels like the Android (Fire TV?) version of MrMC is not getting the attention it used to. I asked a few questions here in the forums about a problem I have with a local Plex server not being discovered, and no answers. Developers used to be more engaged in the pastPerhaps the focus is on other platforms these days?
3.7.1 gone from bad to worse
sirmcftv
Re: 3.7.1 gone from bad to worse
MychaelP
Just stick with Kodi 18. I was in a similar situation as you. Needing to fix Kodi, but now it's the other way around. And here you need to buy the app, yet the support is not as if you bought something, you need to do more of the work to make things work. ugh, that makes terrible sense. So switch back to Kodi, no worries about the sound, just send multi-channel out to the receiver and all is good with the world again. Plus Kodi takes up less precious space on the Fire Stick, almost a third less. Just don't install dumb addons that take more space and you're all set. Enjoy Kodi.
Slickric21
Yeah I’d essentially say this is a dead project by the looks of it on the FireTV.
Support is non-existent in this forum and some of the replies by the author really are just unbelievable.
No help whatsoever, and the lack of patience and communication skills.... wow.....
Kodi is the much better bet now, works much better.
The best bet is to just abandon this software, leave a review on Amazon and spread the word.
I assume that the AppleTV version is where all the attention goes.
