Post by cosmoxl »
Audiomixer wrote: 09 Jul 2019, 01:39 Cosmoxl, interesting. My Lg c8 tv becomes choppy (using nvidia shield) with advanced timing on and fine with it off, yet my Sony 900f lip sync is way off when I have advanced timing on but plays perfectly with it off.
I also have a C8 :) are you running the latest build of MrMC? I certainly saw problems in the past but so far it seems the latest build has fixed it for me. time will tell.
Post by koying »
Never forget to play with the "motion smoother" of your TV, or whatever it is called on whichever brand.
Those alter the timings on the TV itself...
Fehritale
Post by Fehritale »
After the update, MrMC is starting correctly.
One more question: is the service auto starting after a reboot/cold boot or is there a setting to enable it?
Audiomixer
Post by Audiomixer »
cosmoxl wrote: 09 Jul 2019, 02:58
Yup, the latest version. With advanced timing off, everything plays smooth on my c8 including 4K remux HDR content.
koying wrote: 09 Jul 2019, 07:00
Interesting. I run some trumotion on certain content, with tru motion off, advanced timing can be on and still have smooth playback. However, still some mild choppiness with 4K remuxed HDR content even with tru-motion off.
Were my last logs of the plex auto startup of any use?
Post by cosmoxl »
Audiomixer wrote: 09 Jul 2019, 14:30
If real cinema is on it should be handling most any material properly. I'm guessing the "choppiness" you see when tru motion is off is likely just the low frame rate of 23 or 24p material as compared to higher framerate material. You see it especially as the camera pans.
"One downside to OLED technology is that there is some stutter when playing low frame rate content, especially when watching movies or TV Shows."
That quote from https://www.rtings.com/tv/reviews/lg/c8-oled
They explain why in the stutter section of that review. It's actually because the OLED response time is so quick.
Post by koying »
Fehritale wrote: 09 Jul 2019, 12:43 One more question: is the service auto starting after a reboot/cold boot or is there a setting to enable it?
No. You have to start MrMC proper to start the service.
MrMC can be autostarted, though. See "mrmc.autostart" in https://wiki.mrmc.tv/index.php/How_to_s ... _MrMC_data
Fehritale
Post by Fehritale »
So according to the problem with the loading thumbnails for the channels, I still have to start MrMC to get them loading?
Audiomixer
cosmoxl wrote: 09 Jul 2019, 14:52
It was more a stutter choppiness and not a result of panning but more like frames missing.
I’ve read the rtings reviews. Love that site.
In any case I decided to delete cache and data and restart and configure MrMC as new. With advanced timing on, I have not been able to reproduce the choppiness/stutter I had before with advanced timing on.
Post by koying »
Fehritale wrote: 09 Jul 2019, 15:43 So according to the problem with the loading thumbnails for the channels, I still have to start MrMC to get them loading?
Yes. I might add a specific setting just for the service, though
EDIT: Added as "mrmc.autostartservice=yes". Will be in next beta
Fehritale
Post by Fehritale »
koying wrote: 09 Jul 2019, 15:59
Thank you!
