Power Off Menu Item Opacity Skin
magister
Post by magister »
Hello,
I Like Opacity. Unfortunately, I had to revert to Confluence since there is no Power off or close button on the menu in Opacity. Am I missing it? I use a tv remote via HDMI CEC, so I have no Home button. Back button, or exit, does not seem to do it. SPMC and Kodi close out with a double back press, I believe.
Anyway, any plans on adding the power or close button or am I missing a setting?
Re: Power Off Menu Item Opacity Skin
long press on back when at home.
magister
Post by magister »
davilla wrote:long press on back when at home.
I guess the way my Hisense implements cec control is different. It does not recognize long press.
