look in TestFlight app on appletvrubento wrote: 10 Jan 2018, 08:27 One question: when you have signed for TestFlights how the updates arrive? Mine didn't yet.
Regards
Ruben
Testing MrMC 3.4.1
Re: Testing MrMC 3.4.1
- Ted377
Now with tvOS Click Sound. That's Great
Note: focus/zoom effects are disabled right now. (settings -> input -> siri ) Also most Siri related settings there will have no effect. Swipes and pans are always enabled now. Remote idle timer is hooked.
Hints: disable GUI sounds in settings -> appearance. Then you only get tvOS nav sounds. tvOS nav sounds are disabled when playing video because they will mess up passthrough audio. We might fine tune this to only occur if actually doing passthrough, work in progress.
turned off MrMC GUI sounds so there's no conflict and my initial impression is that it's beautiful.
I wonder if a change could be made such that when you're on the home screen and viewing recently added (for example) and you swipe quickly back to the left so that you're back on the main menu that it doesn't from that swipe go a step further to the left to reveal the submenu for whatever section I'm on. Make sense?
When viewing the whole movie section a fast swipe is beautiful when it works. However, more often than not for me it only registers as one step not a fast swipe. And I'm pretty agile with this remote. Seems that fast swipe up registers correctly more often. Fast swipe down is more of a problem. Need a log for this?
rubento
Did you request a TestFlight and did you receive the invitation email?
rubento
- Montoya
Is it normal that TVOS sounds are mixed with MrMC gui sounds, when set to MrMC gui sounds ?
this was already talked about earlier in this thread soon after the new testflight was released.Montoya wrote: 10 Jan 2018, 15:59 Is it normal that TVOS sounds are mixed with MrMC gui sounds, when set to MrMC gui sounds ?
- Montoya
Read all that, but it wasn't clear to me, if that was normal behavior of this Testflight version of MrMC.
And btw, not all of us, have English as their native tongue, to understand things directly
