These items have a Primary image in Emby though. How can I verify the Primary image so MrMC can see them, please?amet wrote: 12 Apr 2020, 05:07Hi?snodrog742 wrote: 12 Apr 2020, 00:00Hello?snodrog742 wrote: 26 Mar 2020, 22:16 Missing covers? Hard to know what shows until you click each one. Uploaded log: R7X5E.log
EDIT: your server doesn't have the Primary image for the video item....
17:12:06.758 T:6096941056 ERROR: CCurlFile::Open failed with code 404 for https://HOSTNAME:443/Items/3385228/Images/Primary|&X-MediaBrowser-Token=EMBYTOKEN 17:12:06.758 T:6096941056 ERROR: Open - failed to open source <https://HOSTNAME:443/Items/3385228/Images/Primary|&X-MediaBrowser-Token=EMBYTOKEN>
Testing MrMC 3.9.7 - Apple TV
snodrog742
Re: Testing MrMC 3.9.5 - Apple TV
not too familiar with Emby to be honest, but quick google search got me this -> https://emby.media/community/index.php? ... ges/page-1snodrog742 wrote: 12 Apr 2020, 17:51These items have a Primary image in Emby though. How can I verify the Primary image so MrMC can see them, please?amet wrote: 12 Apr 2020, 05:07Hi?
its possible that Emby webui and/or other clients fallback to a different image... I cant reproduce here, I have all the images showing correctly on my setup.
snodrog742
It looks like the season doesn't have a Primary Image but the series does. MrMC should fall back to the series poster rather than the season primary image it's looking for.amet wrote: 12 Apr 2020, 18:02not too familiar with Emby to be honest, but quick google search got me this -> https://emby.media/community/index.php? ... ges/page-1snodrog742 wrote: 12 Apr 2020, 17:51These items have a Primary image in Emby though. How can I verify the Primary image so MrMC can see them, please?amet wrote: 12 Apr 2020, 05:07
Hi?
solamnic
Re: Testing MrMC 3.9.7 - Apple TV
thank youamet wrote: 12 Apr 2020, 17:12is this only amber skin related? does it happen if you use other skins?solamnic wrote: 12 Apr 2020, 17:01 uploaded 419ts.log
As i ve mentioned before, files that no nfo can be found can not be played.
Tried to playback file AAAAA.mp4 .... no nfo found, file does not start..
Then played file ..... chapter8-.....mkv which is in the same folder but nfo can be found, file plays normally..
If i rename the file AAAAA.mp4 to a name that can be "recognized"(so nfo can be found) it plays normally
This is no problem with NFS permissions, since they are on the same folder and those files can be played normally either when renaming or if played back from other devices.
I see that NFO file cant be found but I do not see the failed playback anywhere...
EDIT: I can see whats happening, your default "select" action is info.. so it tries to load info for a video file.
settings -> Videos -> File Items - > and select Play or Choose
EDIT1: I'll push a fix for it for the next release
fixed for next testflight/releasesnodrog742 wrote: 12 Apr 2020, 19:06It looks like the season doesn't have a Primary Image but the series does. MrMC should fall back to the series poster rather than the season primary image it's looking for.amet wrote: 12 Apr 2020, 18:02not too familiar with Emby to be honest, but quick google search got me this -> https://emby.media/community/index.php? ... ges/page-1snodrog742 wrote: 12 Apr 2020, 17:51
- Waltman
Is it me or is in progress not quite behaving as it should ?
Examples
- Finished “in progress” episodes only disappear from “in progress” after I entered tvshows and return home.
- And today a movie “in progress” only appeared “in progress” after I entered movies and return home. The progress bar was visible on the poster in “recently added movies”.
Is this traceable with debuglogging ? Has someone noticed this ?
Examples
SETTOP-BOX :Apple TV 4K
Skin: Ariana
Database: MySQL
NAS: Synolgy DS1513+
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
There is a setting to hide watched recently added itemsWaltman wrote: 13 Apr 2020, 18:50 Is it me or is in progress not quite behaving as it should ?
Examples
- Waltman
Yes I know you kind can hide watched status. That setting is in use.
But my question is about the in progress not acting as it should. At had a movie in progress
, but after I stopped the movie It did not turn up in “in progress”. The progress bar was only visible on the movie poster. Only after I entered movies and returned to the home screen, the movie appeared in the “in progress” section.
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
- Ted377
THX for the Infobar.
• when i switch the channel there will only be show the timeline
• the channel icon is also not displayed
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Hopefully fixed for next TestFlightWaltman wrote: 14 Apr 2020, 16:43 Yes I know you kind can hide watched status. That setting is in use.
