When on the MrMC home screen with Ariana, holding down a click of the siri remote on a file should bring up a menu where we have a choice of info or mark as watched/unwatched, or some other things, right?
I just realized all I get is something about favorites.
Log is JBO57
Testing MrMC 3.9.2 - Apple TV
jabohn
Re: Testing MrMC 3.9.2 - Apple TV
After installing the latest build, it switched the Arianna theme to light. It's set to use the System settings which is dark. I had to manually tell it to be dark now.
That’s odd, it works fine here... what is your tvOS version?jabohn wrote: 18 Sep 2019, 03:36 After installing the latest build, it switched the Arianna theme to light. It's set to use the System settings which is dark. I had to manually tell it to be dark now.
Yeah, I see it as well... I’ll look into itcosmoxl wrote: 18 Sep 2019, 02:29 When on the MrMC home screen with Ariana, holding down a click of the siri remote on a file should bring up a menu where we have a choice of info or mark as watched/unwatched, or some other things, right?
Log is JBO57
jabohn
tvOS 13.
Log is JBO57
new build should have this fixed, let us know please... still being built so it might be tomorrow if @davilla crashes
- Montoya
Problem still exits in current TF, just like it did in 3.9.0 TF and stable etc.Montoya wrote: 08 Sep 2019, 21:31Latest stable and beta Emby servers combined with this viewtopic.php?f=23&t=4708. Just flick the requested switch mentioned in topic, to see what is wrong in UI workflow, browsing Emby libraries.davilla wrote: 08 Sep 2019, 21:02I would have to understand the exact problem, "Emby nodes" means nothing to me, they are all 'nodes' in one form or fashon in code:)Montoya wrote: 08 Sep 2019, 20:50
Can you add the Magic Sauce back again, over the Emby feature that was introduced with MrMC 3.8.1 (Emby nodes), where the taste got crippled in the UI workflow, in LATEST iOS/tvOS MrMC releases.
Seems that most Emby users here have a different taste or can't taste at all, because they don't seem to miss that Sauce...
3.9.2 (190918.2335)
emby: “fix” filter options
tvos: remove Favourites keymap from home, we need long hold to work for homeshelf items
tvos: set dark mode on startup, tvos 13 is handling it differently somehow
tvos: we had dark mode since version 10
long click brings up menu now and after a reboot it was in dark mode as it should be. thanks.davilla wrote: 19 Sep 2019, 01:37 3.9.2 (190918.2335)
jabohn
Dark mode issue is fixed for me too.
