TV Infobar Topic is solved
Any Opacity skin issues go here
Ted377
Re: TV Infobar
Post by Ted377 »
When we get the Play / Pause FW BW bar, we can also select the respective function. In the info bar, this function could be fundamentally related to the current program. Sure enough? :lol:
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
Montoya
Re: TV Infobar
Post by Montoya »
Ted377 wrote: 25 Mar 2019, 17:35 When we get the Play / Pause FW BW bar, we can also select the respective function. In the info bar, this function could be fundamentally related to the current program. Sure enough? :lol:
In 3.8.0 we have 2 kinds of (bottom) bars:
1) With control buttons only
2) With seek bar only (no controls)
Number two, is the current pimped Bottom Info Bar with Now/Next etc, in current TF, so let see what the Devs have to say what is possible.
Ted377
Re: TV Infobar
Post by Ted377 »
Montoya wrote: 25 Mar 2019, 17:45
I already know what you mean. But this is a different site than the retrieval of the description.
To get back to your problem ... for skipping right-click and left-click, a simple timeline is enough to see if you spool 10, 20, 30 ... seconds forward or backward. Am I correct ?
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Re: TV Infobar
Ted377 wrote: 25 Mar 2019, 17:30 Click on OK confirms this point and goes over to the description.
thats just a label and its not selectable ... there is ways to do it I think but would have to search
but "back" does that , it closes info bar and opens up the Top Info
we need to come up with names to describe all 4 different parts of this OSD :)
Ted377
Re: TV Infobar
Post by Ted377 »
amet wrote: 25 Mar 2019, 17:53
As I said, it would just be an idea 😉
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Re: TV Infobar
I am staying out of this discussion if thats okay with you two, let me know in step-by-step how you want to see this OSD work on livetv... I can be more constructive elsewhere :)
once we get the functionality sorted out, we can move onto making it pretty ...
okay?
EDIT: I'll step in if something is not technically possible :)
Ted377
Re: TV Infobar
Post by Ted377 »
amet wrote: 25 Mar 2019, 17:57 I am staying out of this discussion if thats okay with you two, let me know in step-by-step how you want to see this OSD work on livetv... I can be more constructive elsewhere :)
okay?
That's alright. I will consult with Montoya 😉
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Montoya
Re: TV Infobar
Post by Montoya »
Ted377 wrote: 25 Mar 2019, 17:52 To get back to your problem ... for skipping right-click and left-click, a simple timeline is enough to see if you spool 10, 20, 30 ... seconds forward or backward. Am I correct ?
I just want to see on screen in text what happens, when I hammer my remote multiple times Left/Right for skipping FW/BW. I have no laser scan vision like Robocop, to see on seek bar, how many pixels the seek bar has changed ;)
Reverting back now to 3.8.0 until Skip FW/BW is taken care of, to keep family happy ;)
Montoya
Re: TV Infobar
Post by Montoya »
Ted377 wrote: 25 Mar 2019, 17:59
okay?
We will do some brain storming and get back to you @Amet
Ted377
Re: TV Infobar
Post by Ted377 »
It would be enough if skipping is displayed in the infobar. But how would you want to implement that?
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
