testing MrMC 3.2.0
Re: testing MrMC 3.2.0
Can I get a debuglog from someone running the current version under a 4K display. Thx.
Post by timstephens24 »
Do you want anything in particular?
thx
Another version brewing. Sure helps when you have an physical device to play with :)
Montoya
Post by Montoya »
Just a new user of MrMC (but experienced user of Kodi) and was wondering why no TV channel title or media title is available when you pause a TV channel or movie in the Opacity skin.
I'm on testflight program and see in Amber skin that that above info is shown, when pausing a movie or TV channel.
Is this work in progress with the Opacity skin ?
Apple TV 4K 64GB, Win10 Pro x64 1703 build15063.608
Kodi 18.0-ALPHA1 Git:20170920-2bdd690
Opacity is very simple skin, our aim was to leave all complicated and heavy stuff for Amber and MrMC skin(confluence).
Montoya
Post by Montoya »
OK, but when I switch TV channels, information about channel title and EPG info of current channel is shown, so you partly left it out which I find strange.
For users with PVR backends like DVBlink, TVheadend, Simple Client etc, channel title and EPG info of current channel, in pause mode or in the mode where you have the pause, forward, rewind controls , audio settings etc, will be appreciated.
Noted, we will discuss internally
Montoya
Post by Montoya »
Thanks Amet, keep up the good work with MrMC :mrgreen:
