well, extension exclusions are semi correct, for example. .pvr is in that list but it is always excluded. wip
this was more a quick way to deal with strm's.
Testing MrMC 3.4.1
eazytv
Re: Testing MrMC 3.4.1
Thx, amet! IP Remote is working like charm. Again.
- Montoya
Thanks Davilla, for implementing extensions exclusions and perfect that you added a list of extensions to block !davilla wrote: 06 Feb 2018, 18:53 well, extension exclusions are semi correct, for example. .pvr is in that list but it is always excluded. wip
Just tested this and here are my remarks:
1) blocking .strm still gives scrubber with strm files, when I pause with touchpad
2) blocking file extensions like .mkv .avi .mp4, which are contained in the stream URL inside the .strm DOES block scrubber
3) setting of extensions in MrMC profiles other than master profile doesn't work, profiles seems to use setting of Master profile for blocking scrubber. Those other profiles were created with copy from default.
CallClear
Hi. In the 3.5 release candidate, up and down clicks only do big skips for me now. They are no longer skipping chapters when available. Has anyone else noticed this?
CallClear wrote: 07 Feb 2018, 03:08 Hi. In the 3.5 release candidate, up and down clicks only do big skips for me now. They are no longer skipping chapters when available. Has anyone else noticed this?
chapters are working for me.
Chapters jumps only happen if the video in question has chapters. Big seeks have been disabled. You should see the chapters in the progress bar, left side in Opacity.CallClear wrote: 07 Feb 2018, 03:08 Hi. In the 3.5 release candidate, up and down clicks only do big skips for me now. They are no longer skipping chapters when available. Has anyone else noticed this?
CallClear
Hi. The files do have chapters available and work as expected on my Shield and Fire TV versions of MrMc. It is not working on my Apple TV (4th Gen) only after updating on testflight to 3.5. It worked fine on the previous version after you implemented chapter skip when available. I'm not sure why I'm the only person seeing this but I'm happy to provide logs, etc. Just let me know. Thanks!
debuglog pleaseCallClear wrote: 07 Feb 2018, 14:25 Hi. The files do have chapters available and work as expected on my Shield and Fire TV versions of MrMc. It is not working on my Apple TV (4th Gen) only after updating on testflight to 3.5. It worked fine on the previous version after you implemented chapter skip when available. I'm not sure why I'm the only person seeing this but I'm happy to provide logs, etc. Just let me know. Thanks!
CallClear
Will do. I'll fire it up and get a log as soon as I get home from work. Thanks!!
https://gist.github.com/anonymous/b9afa ... 3fa6e28541
https://gist.github.com/anonymous/2639c ... fd45c90b79
I'm getting a pretty regular crash.
I press menu to exit out of playback. Refresh rate change, so things are blank for a few seconds. When the GUI returns it's frozen.
Items in recently added, for example, seem to be missing or sometimes the whole GUI is dimmed too.
The cursor won't move but I can hear the cursor sound effect as I tap the remote.
The web interface says "connection to server lost".
The log I pasted above is from "old" after I restarted MrMC.
To get things working again I have to pull up the task switcher and fully close MrMC. Just pressing menu and then re-opening MrMC doesn't fix it.
