Well, right now, you are the only one that has mentioned xxx.strm files. So unless someone else chimes in, no scrubbing via xxx.strm filesMontoya wrote: 03 Feb 2018, 20:34 Wouldn't that effect users who have other strm content (without connection limit) and would like to to use scrubbing, if no option in settings is present ?
If you block all strm content from scrubbing maybe those users wouldn't be happy, if no option to set it, is present.
Testing MrMC 3.4.1
Re: Testing MrMC 3.4.1
- Montoya
Haha, OK
If its possible, I would still like a setting to turn it on or off. So when my kids are to bed, they don't occupy an iptv connection anymore, so in that case I would like to turn scrubbing for strm on again.
smiffy1989
Anyone else getting a random black screen in the middle of watching live TV? It's like the refresh adjust but doesn't cause a pause.
Only thing that seems to stick out in the log is:
19:46:08 T:6120484864 DEBUG: JSONRPC: Value does not lay between minimum and maximum in type playlistid
^^which appears in the logs every time I get the flash (full log: https://gist.github.com/anonymous/59726 ... 8ac6534477)
I've recently bought a second apple TV and set up MySQL so I can keep recording progress in sync between rooms, I'll try revert and see if it still happens.
I don't think I've seen that.smiffy1989 wrote: 05 Feb 2018, 19:53 Anyone else getting a random black screen in the middle of watching live TV? It's like the refresh adjust but doesn't cause a pause.
SUPERBIF
Will it be possible to get an updated version of TVHeadend? The newer version are better than the older ones. Thanks for the work.
please use TF thread for anything to do with current tests.. thanks!
v3.5.0 (180206.1539) @20180206-a2c484d
core: complete refactor tvOS focus handling
core: focus engine, add FocusLayerViewSlider
core: default to tvos native click sounds
core: exclude folders named _gsdata_, aka GoodSync bread crumbs
core: add TVOSDirectory so we can get to home userdata xml files
core: add CGUIDialogOSDSettings window
Core: add reload keymap button in settings
emby: fix collections listes in movie lists
fixed: dolby vision detection for VTB/AVF codecs
fixed: crashing in libsmbclient, smb.GetImpl might return null so check it
fixed: block skins from issuing an exit under darwin. not permitted
update: skins to support focus engine
changed: deterlacer/auto for appletv4k to VS_INTERLACEMETHOD_DEINTERLACE_HALF
settings: change to more sensible defaults for novice users
services: LightEffects cleanup of the thread
backport: various backport fixes
This is release candidate. Version was bumped as this was not minor fixes.
what's changed from the last testflight? nothing jumped out at me.davilla wrote: 06 Feb 2018, 17:29 v3.5.0 (180206.1539) @20180206-a2c484d
and added scrubbing exclusion list in settings -> system -> input
As rc, many commits have been smashed down, it went from 180+ to 90. So this list is more a highlights list.
Awesome job.davilla wrote: 06 Feb 2018, 18:32 add reload keymap button in settings
So by default no extensions are disabled it looks like. I have to suggest, if possible, that the color change of extensions that are selected to be disabled for scrubbing be made more obvious. I can barely see that color change.
