testing MrMC 3.1.0
three6zerocool
Re: testing MrMC 3.1.0
Post by three6zerocool »
Enjoying the new Opacity skin.
Have Plex service configured for Movies. and TV Shows.
If I select TV Shows from main menu, I get list of shows, as expected.
But, if I press back button, instead of returning to previous main menu, I get a list of years.
If I press back button again, it displays Files and Playlists.
Is this by design?, or have I accidentally set some filter or something?.
Just wondered, as it seems kinda counter intuitive.
Itzme1234
Post by Itzme1234 »
I also found myself sort of stuck in an in-intended section, trying to replicate that issue. I was in my TV shows... somehow, hitting the back button I'm now trapped in Media sources, Music, Picturs, Video. Hitting back or menu just clicks. In fact I had to fully close MrMc (swipe it up) to get out of that.
Itzme1234
Post by Itzme1234 »
I'd also like to set where the app first opens, if I can't set it could it be the section I was last using maybe? For now it seems to put me into TV, not the TV that hasn't TV shows, the other one that we can't turn off.
three6zerocool wrote: 28 Jul 2017, 04:10 If I select TV Shows from main menu, I get list of shows, as expected.
It's a bug, as it getting 'trapped'. We thought we found and fixed all of these but it seems the root cause is still lurking.
Post by cosmoxl »
My thoughts on the skin.
1) Whether the current selection color is blue or red (default) or green the contrast is sometimes too high with regard to the selected item. Maybe make opacity slightly less? It tends to make small text, such as in DVR TV guide, difficult to read.
2) There seems to be wasted space at the bottom on the TV guide. The show description only takes up a small portion. Perhaps increase the font size in the guide. There seems to be plenty of space in the grid itself. And perhaps you can use the wasted space by allowing more lines of the grid to show.
3) In the video info along the bottom (rating, dimension, aspect ratio, etc.) I'd like to see the video codec as well.
4) I definitely agree that the area that currently has recently added TV or movies could use an in progress line as well.
5) The currently selected episode/movie poster (in recently added) is slightly larger than the others. But, this might not be enough of an indicator for some people. Could something more be done to indicate the currently selected item?
6) As episodes/movies are selected (in recently added) could we have their media info at the bottom instead of the news scroll?
jabohn
Post by jabohn »
Itzme1234 wrote: 28 Jul 2017, 13:02 I'd also like to set where the app first opens, if I can't set it could it be the section I was last using maybe? For now it seems to put me into TV, not the TV that hasn't TV shows, the other one that we can't turn off.
You can choose the default location in settings.
jabohn
Post by jabohn »
cosmoxl wrote: 28 Jul 2017, 14:16 5) The currently selected episode/movie poster (in recently added) is slightly larger than the others. But, this might not be enough of an indicator for some people. Could something more be done to indicate the currently selected item?
I was thinking this too.
Itzme1234
Post by Itzme1234 »
jabohn wrote: 28 Jul 2017, 15:16
If you mean in startup window/home window, that isn't changing anything for me. It doesn't even offer me "Movies" or "TV shows" which are my only two categories in use.
jabohn
Post by jabohn »
Itzme1234 wrote: 28 Jul 2017, 13:02 If you mean in startup window/home window, that isn't changing anything for me. It does even offer me "Movies" or "TV shows" which are my only two categories in use.
Must be a bug then.
jabohn
Post by jabohn »
jabohn wrote: 28 Jul 2017, 03:54 BUG - I just updated my library to add a new episode of "Whose Line is it Anyway?" and it added the episode - it shows up in recently added - but the entire show disappeared from the TV Show list right in front of my eyes. Doesn't seem to be skin related.
Any ideas how I can get the missing show back? I've tried quitting and restarting, updating the library again etc.
What's the best way to capture the logs? Obviously I can't recreate this again, all I can send is logs in the current state.
