Testing MrMC 3.8.0 - [Invites Closed]
monkbolt
Re: Testing MrMC 3.8.0 - [Invites Closed]
Post by monkbolt »
Audio passthrough is still broken on 11.2, here's the log from the newest build.
What's going to happen when the last 3.7.1 build expires, could I just keep using it or will I be forced to update?
monkbolt wrote: 24 Feb 2019, 18:16 Audio passthrough is still broken on 11.2, here's the log from the newest build.
don't see the previous resync'ing errors in log.
what exactly is happening on your end ?
testflight builds last 90 days. That time period is out of our control.
monkbolt
Post by monkbolt »
Only crackling/popping noises from my speakers.
monkbolt wrote: 24 Feb 2019, 18:34 Only crackling/popping noises from my speakers.
ahhh, maybe I see the issue. new testflight is brewing.
3.8.0 (190224.1858)
skin syncs
core: iOS/tvOS (11.2) needs IEC packed
monkbolt
Post by monkbolt »
davilla wrote: 24 Feb 2019, 23:01 3.8.0 (190224.1858)
skin syncs
That fixed it! Thank you very much!
edit: I wish files with AC3 stereo tracks would default to PCM if they can't be passed through since they seem to confuse my receiver and I have to manually turn passthrough off. That's been the case for a long time (maybe always?) though, not just in 3.8.
solamnic
Post by solamnic »
something changed on latest build?
i have constant video hicups.. (playing over Lan - windows 10 - nfs)
(latest testflight, 12.2 latest beta)
solamnic wrote: 25 Feb 2019, 22:04 something changed on latest build?
plays fine here :)
solamnic
Post by solamnic »
https://pastebin.com/8uXFPTZg
here is my log file
solamnic
Post by solamnic »
Btw nuc with Libre plays the same files with no problems, can you please check?
